Good Day Everyone!
First time here!
I'm using a 5202 motor with a micro controller with an RC interface. I want to monitor the speed of the motor through the encoder.
I based my sketch off of one that used a potentiometer to control the motor, but I use an RC unit to do that. I commented out the lines for the potentiometer control.
My sketch won't compile. Please help.
Here's my sketch:
Gearmotor Rotary Encoder Test
motor-encoder-rpm.ino
Read pulses from motor encoder to calculate speed
Control speed with potentiometer
Displays results on Serial Monitor
Use Cytron MD10C PWM motor controller
DroneBot Workshop 2019
https://dronebotworkshop.com
// Motor encoder output pulse per rotation (change as required)
#define ENC_COUNT_REV 537
// Encoder output to Arduino Interrupt pin
#define ENC_IN 3
// MD10C PWM connected to pin 10
#define PWM 10
// MD10C DIR connected to pin 12
#define DIR 12
// Analog pin for potentiometer
int speedcontrol = 0;
// Pulse count from encoder
volatile long encoderValue = 0;
// One-second interval for measurements
int interval = 1000;
// Counters for milliseconds during interval
long previousMillis = 0;
long currentMillis = 0;
// Variable for RPM measurement
int rpm = 0;
// Variable for PWM motor speed output
int motorPwm = 0;
// Setup Serial Monitor
// Set encoder as input with internal pullup
pinMode(3,INPUT_PULLUP);
pinMode(ENC_IN, INPUT_PULLUP);
// Set PWM and DIR connections as outputs
pinMode(PWM, OUTPUT);
pinMode(DIR, OUTPUT);
// Attach interrupt
attachInterrupt(digitalPinToInterrupt(3), updateEncoder, RISING);
attachInterrupt(digitalPinToInterrupt(ENC_IN), updateEncoder, RISING);
// Setup initial values for timer
previousMillis = millis();
// Control motor with potentiometer
motorPwm = map(analogRead(speedcontrol), 0, 1023, 0, 255);
// Write PWM to controller
analogWrite(PWM, motorPwm);
// Update RPM value every second
currentMillis = millis();
if (currentMillis - previousMillis > interval)
// Calculate RPM
rpm = (float)(encoderValue * 60 / ENC_COUNT_REV);
// Only update display when there is a reading
if (rpm > 0)
Serial.print("PWM VALUE: ");
Serial.print(motorPwm);
Serial.print('\t');
Serial.print(" PULSES: ");
Serial.print(encoderValue);
Serial.print('\t');
Serial.print(" SPEED: ");
Serial.print(rpm);
Serial.println(" RPM");
encoderValue = 0;
void updateEncoder()
// Increment value for each pulse from encoder
encoderValue++;
