555 timer, what resistor and capicitor to use.
Hi i want to use a 555 timer to trigger a HC-SRo4 sensor and with what i can gather it needs a 10us pulse to trigger it.
I cant seem to calculate what resistor and capacitor will be needed?
Many thanks.
Edit, it needs to be in a monostable circuit.
Try this
Thanks Grumpy
That helps a lot but Im not getting it exactly on 10 microseconds how exactly do you think the pulse must be ?
M...
Not exact at all.
Where does it say it needs 10uS?
It says:-
Using IO trigger for at least 10us high level signal,
That means that a signal greater than 10uS is needed. It does not mean it has to be 10uS.
Ok so anything above and close to that will work then.
Many thanks Grumpy.
