5th Encoder
Hi All, I am completely new to Audrinio and tried the facebook groups, but no help has been offered.
I have a button box and im using the attached Sketch.
Is it possible to change the sketch to add a 5th Rotary encoder, I don’t mind losing a few buttons in the sketch and changing the board from a pro micro to an Uno or Mega if I have too.
Also, as a side question, my LED toggle will not light when switched on. I have connected the led to the 5v and chained it to the on connector (sorry for my terms, I have no experience )
The Sketch is,
//BUTTON BOX
//USE w ProMicro
//Tested in WIN10 + Assetto Corsa IRACING
//SKULL SIMGEAR
#include <Keypad.h>
#include <Joystick.h>
#define ENABLE_PULLUPS
#define NUMROTARIES 4
#define NUMBUTTONS 24
#define NUMROWS 5
#define NUMCOLS 5
byte buttons[NUMROWS][NUMCOLS] = {
{0, 1, 2, 3, 4},
{5, 6, 7, 8, 9},
{10, 11, 12, 13, 14},
{15, 16, 17, 18, 19},
{20, 21, 22, 23},
struct rotariesdef {
byte pin1;
byte pin2;
int ccwchar;
int cwchar;
volatile unsigned char state;
rotariesdef rotaries[NUMROTARIES] {
{0, 1, 24, 25, 0},
{2, 3, 26, 27, 0},
{4, 5, 28, 29, 0},
{6, 7, 30, 31, 0},
#define DIR_CCW 0x10
#define DIR_CW 0x20
#define R_START 0x0
#ifdef HALF_STEP
#define R_CCW_BEGIN 0x1
#define R_CW_BEGIN 0x2
#define R_START_M 0x3
#define R_CW_BEGIN_M 0x4
#define R_CCW_BEGIN_M 0x5
const unsigned char ttable[6][4] = {
// R_START (00)
{R_START_M, R_CW_BEGIN, R_CCW_BEGIN, R_START},
// R_CCW_BEGIN
{R_START_M | DIR_CCW, R_START, R_CCW_BEGIN, R_START},
// R_CW_BEGIN
{R_START_M | DIR_CW, R_CW_BEGIN, R_START, R_START},
// R_START_M (11)
{R_START_M, R_CCW_BEGIN_M, R_CW_BEGIN_M, R_START},
// R_CW_BEGIN_M
{R_START_M, R_START_M, R_CW_BEGIN_M, R_START | DIR_CW},
// R_CCW_BEGIN_M
{R_START_M, R_CCW_BEGIN_M, R_START_M, R_START | DIR_CCW},
#else
#define R_CW_FINAL 0x1
#define R_CW_NEXT 0x3
#define R_CCW_BEGIN 0x4
#define R_CCW_FINAL 0x5
#define R_CCW_NEXT 0x6
const unsigned char ttable[7][4] = {
// R_START
{R_START, R_CW_BEGIN, R_CCW_BEGIN, R_START},
// R_CW_FINAL
{R_CW_NEXT, R_START, R_CW_FINAL, R_START | DIR_CW},
// R_CW_BEGIN
{R_CW_NEXT, R_CW_BEGIN, R_START, R_START},
// R_CW_NEXT
{R_CW_NEXT, R_CW_BEGIN, R_CW_FINAL, R_START},
// R_CCW_BEGIN
{R_CCW_NEXT, R_START, R_CCW_BEGIN, R_START},
// R_CCW_FINAL
{R_CCW_NEXT, R_CCW_FINAL, R_START, R_START | DIR_CCW},
// R_CCW_NEXT
{R_CCW_NEXT, R_CCW_FINAL, R_CCW_BEGIN, R_START},
#endif
byte rowPins[NUMROWS] = {21, 20, 19, 18, 15};
byte colPins[NUMCOLS] = {14, 16, 10, 9, 8};
Keypad buttbx = Keypad( makeKeymap(buttons), rowPins, colPins, NUMROWS, NUMCOLS);
Joystick_ Joystick(JOYSTICK_DEFAULT_REPORT_ID,
JOYSTICK_TYPE_JOYSTICK, 32, 0,
false, false, false, false, false, false,
false, false, false, false, false);
Joystick.begin();
rotary_init();
CheckAllEncoders();
CheckAllButtons();
void CheckAllButtons(void) {
if (buttbx.getKeys())
for (int i = 0; i < LIST_MAX; i++)
if ( buttbx.key*.stateChanged )*
    _ switch (buttbx.key*.kstate) {_
    _
    case PRESSED:_
    _
    case HOLD:_
    _ Joystick.setButton(buttbx.key.kchar, 1);
    case RELEASED:
    case IDLE:
    Joystick.setButton(buttbx.key.kchar, 0);
    }*_
void rotary_init() {
* for (int i = 0; i < NUMROTARIES; i++) {*
_ pinMode(rotaries*.pin1, INPUT);
pinMode(rotaries.pin2, INPUT);_
#ifdef ENABLE_PULLUPS*
_ digitalWrite(rotaries*.pin1, HIGH);
digitalWrite(rotaries.pin2, HIGH);
#endif*
}*_
unsigned char rotary_process(int _i) {
* unsigned char pinstate = (digitalRead(rotaries[_i].pin2) << 1) | digitalRead(rotaries[_i].pin1);
rotaries[_i].state = ttable[rotaries[i].state & 0xf][pinstate];
return (rotaries[i].state & 0x30);*
void CheckAllEncoders(void) {
* unsigned char result = rotary_process(i);
if (result == DIR_CCW) {
Joystick.setButton(rotaries_.ccwchar, 1); delay(50); Joystick.setButton(rotaries.ccwchar, 0);
};_
if (result == DIR_CW) {
Joystick.setButton(rotaries_.cwchar, 1); delay(50); Joystick.setButton(rotaries.cwchar, 0);
wiring guide.JPG*_
Sure, if you have spare pins. Just modify these lines…
  {0, 1, 24, 25, 0},
  {2, 3, 26, 27, 0},
  {4, 5, 28, 29, 0},
  {6, 7, 30, 31, 0},
Code tags look like this [​code][​/code]. Please use them when posting code on the forums. You can insert them via the </> button on the toolbar.
I can't see any code in your sketch to toggle a LED?
"on connector" makes no sense, sorry. Say which pin of the Arduino ProMicro. Even better, draw a circuit diagram.
Do you have a current limiting resistor?
Hi
thanks for the reply, as ,mentioned i am completely new to this so please accept my apology in my terms.
I have two, toggle switches with a led light then end, i was hoping for them to light when on. and no i dont have a current limiting resistor
pcbbc:
 {0, 1, 24, 25, 0},
 {2, 3, 26, 27, 0},
 {4, 5, 28, 29, 0},
 {6, 7, 30, 31, 0},
Code tags look like this . Please use them when posting code on the forums. You can insert them via the </> button on the toolbar.
pcbbc:
 {0, 1, 24, 25, 0},
 {2, 3, 26, 27, 0},
 {4, 5, 28, 29, 0},
 {6, 7, 30, 31, 0},
Ok the Pro Micro has no spare pins, so i could use a Mega ? not how do i modify, add the pin numbers like the others ?
hi
i really dont know to modify the lines, could you help please.
Code: [Select]
{0, 1, 24, 25, 0},
{2, 3, 26, 27, 0},
{4, 5, 28, 29, 0},
{6, 7, 30, 31, 0},
