“Wiring Instruction : A (Blue), B (Pink), C (Yellow), D (Orange), E (Red, Mid-Point)”
I’ve attached my schematic below.
I uploaded the ‘stepper_oneRevolution’ sketch from the stepper examples in the ide, add changed the code below to 64 steps as according to the info given these have a step angle of 5.625deg. So 360/5.625 = 64 steps.
const int stepsPerRevolution = 64; // change this to fit the number of steps per revolution
// for your motor
After several attempts and searching through the forums trying a couple of different combinations for the outputs of the arduino, I am unable to get this motor to do one complete revolution in 64 steps!!
Angrily (tired at this point), I picked up my mini vice and with a well aimed (all be it accidental) shot, managed to put a rather large dent in my guitar!! LOL.
So just wondering if anyone can shed light on how to get these motors working!!
If the data sheet is to be trusted it has a resistance of 130R this only gives a current of 38mA which is small.
Is the motor turning consistently through a specific angle? Have you slowed it down, if they go too fast they skip pulses. You could try a higher voltage, like that on the Vin pin if using an external power supply.
I guess it is too late to say as you might have already found the answer, but.. I had the same problem too. I read many forums and I ended in the conclusion that there is somethin going on with the gear reduction. It seems that (it worked for me) you have to go up to 2048 steps for a full 360 degree rotation. You also have to set speed at 200 max as the gear reduction won't let it speed up more. And double check the sequence too.
dutchboy:
Sounds like someone needs to grow up or get some anger management classes... Sure wasn't worth the mark in the guitar and didn't help the vise any...
How far was it turning? Was it repeatable. Those 2 will give you quite a bit of the answer of whether it is working. Next is - How fast are you stepping? If you are stepping too fast you WILL miss steps. Could just about drive this one directly from the Arduino - just add diodes across the windings. (Diodes won't conduct when the Arduino is at 5 V.)
