5V 8 relay module
hello!
i am trying to connnect 16 buttons to two 5v 8 relay modules on an 5V 6A power supply.
i have connected +5 to vcc in far left pin/ ground to GND far right pin and use GND to send singal.
the problem i have is that i can have active only 3 replys, if i try to close more than 3 relays nothing happens.
i have a wire running prox 20 metres but 5v do get at the end of the line.
  • if that can help i have an other 5v power supply close to the relays used to power 10 arduino nano.
What is the size of the 20M of wire?
Where is the Arduino in all this?
wiring is UTP i sent 1 pair + and 1 pair -
the arduino is just to explain what the second power supply powers in case that it can be used also for the relays
