My project is using an arduino mega board as well as a number of 3.3v components which when all running at full pelt could draw in excess of 200ma, the arduino mega will also power a 320x240 tft
and 4(currently) 5v relay boards in addition to sensors and llc boards to allow 5 to 3.3v comms
So for the real project i want a PSU, I have bought a 12v 25w switching psu which i intend to box up with the 240v a/c switching relays and step down voltage boards and connect to the arduino project box with a multicore flex.
The plan is to use a dc-dc step down converter board (ebay) based on a LM2596 with a pot to tune down the output to 5v, and then use a LM117 board to step that 5v down to 3.3v.
I also want to supply 12v to the project box to run fans when internal temp sensors indicate it necessary.
so can i use 1 x +12v feed off the 12v psu, 1 x +5v feed off the LM2569, and 1 x +3.v3 off theLM117 and use a common ground from the 12v PSU to supply the power to my project?? or should i take the common ground off the last dc converter in the chain the LM117?, or should i belt n braces connect all three grounds?
I would rather check first than fry all my boards and watch the magic smoke dissipate..
thanks in advance
