5v DC motor is dead and I don't know why
Hello everybody!
This is my very first electronic project, so sorry if this is trivial to you guys or if my explanations don't make sense... :slight_smile:
I'm working on an Arduino project to operate a 5V pump (to scare away pigeons) using a HC-SR501 PIR motion detector. My circuit works fine, but I've noticed a problem:
Symptom: The 5V motor/pump worked at first, but after a while testing it, it is now gradually slowing down until it stop completely.
Current circuit:
PN2222 transistor to control the pump.
9V 1A Power Adapter
MB-V2 power supply module
PIR (HC-SR501) output signal triggers pump via resistor and transistor and 5v relay (5pins).
Without the transistor, the pump doesn't work (probably because the PIR also consumes current).
Do you see a problem in my project that could explain the motor being damaged ? I've linked an image of the circuit and the photo of the real one.
Lack of a back-EMF diode across the motor.
Yes. Running those submersible pumps out of water will destroy them. They MUST be in water.
