5V DC motor not working
I’ve been following the arduino tutorial provided by Plusivo, and I reached the DC motor chapter, I managed to get it working once, then went on to powering it with a relay, but then everything broke, the DC motor worked for 5 seconds then stopped, then I tried placing one of the motors wires into the other relay pin and the DC was working but without control, as if it was just powered directly to the power supply. I tried to power the DC motor without the relay and now it doesn’t work at all. I tried testing if the L293D wasn’t working, so I placed an LED but it works just fine. and for some reason one side of the L293D doesn’t work, I kept switching it around to see if I was placing it wrong, but ended up breaking one of the enable pins, but luckily it was the one from the side that wasn’t working. I provided images of the how it works with the other relay pin, and how the LED is working just fine and how the wires are placed in the original power supply/L293D/DC motor connection.
Photos:
Please make your images visible in your Post. See this Simple Image Posting Guide
Also, please post your program. See How to use the forum
...R
Pin 8 of the L293 (motor power) is not connected.
Not sure if the L293 will have survived that.
Leo..
