5V input and short Vin and 5V? [solved]
Hello,
I have a regulated 5V power supply with a power jack. Can i plug it into the Arduino and shunt (edit : short) the 5V pin and the Vin pin to have 5V for the microcontroler? Is there a risk to damage the board? Otherwise i have to ad a female power jack on my shield…
Thanks!
Yes you can do that if you mean shorting instead of shunting. The only danger is if some one plugs a higher voltage into this thinking it is a normal arduino.
Thanks a lot!!!
I meant shorting ;-)
