5V Out causes reset?
I'm doing a basic push button circuit. When I unplug my arduino R3 from usb and connect it to 9V battery, the 5V output causes my arduino to reset when I push my push pin. My LED never turns on. When I push my normally closed button, the voltage jumps to 0V.
EDIT/SOLUTION: I’m a total dummy and thought the internally connected part of the push button were the parts that get connected when you depress it The aforementioned link help me understand it better. I was essentially connecting 5V, DIO2, and a resistor (already to gnd) to gnd all in parallel when I depressed the button. Push Button/Tactile Switch Pinout Connections, Uses, Dimensions & Datasheet
Here's my code
const int wire = 5;
bool state= false ;
int cycle=0;
bool prevState=false;
    pinMode(2,INPUT);
    pinMode(wire, OUTPUT);
    analogWrite(9,255);
  state = digitalRead(2);
  if(input==LOW)
    if(state!=prevState)
      Serial.println("Button Pressed");
      cycle=cycle+1;
      if(cycle%2)
        analogWrite(wire,255);
        analogWrite(wire,0);
      if(cycle>9)
        cycle=0;
  prevState=state;
High current draw thru the 100 ohm resistor takes down the 5V line, thus reset.
Do instead: Connect the button between D2 and Gnd.
Change this line: pinMode(2,INPUT);
to pinMode(2,INPUT_PULLUP);
Now the internal pullup will hold the pin at the HIGH level.
Remove the 100 ohm from the circuit.
CrossRoads:
My button is normally closed though, so arent I just then directly connecting 5V to ground if I remove the resistor. I tired doing what you mentioned to no success.
I see that the rated input into the i/o is 50 mA (0.05A). I replaced the 100 ohm resistor with a 100K resister, but it still causes it to reset for some reason. Any idea why?
