Does anyone have a circuit for a 5 volt to 12 volt inverter?
Any help is needed.
Thank you in advance,
Jaredpi
hav a look at the MAX662A DC/DC-Converter. A sample circuit can be found at the datasheet: http://datasheets.maxim-ic.com/en/ds/MAX662A.pdf
Regards
Kai
Unless the current required from +12v is very small, the inverter will involve a transformer or inductor and it's easier to buy a ready-made DC-DC converter. If you do want to build your own, there are lots of switching regulator ICs to choose from. The data sheets generally describe how to use them and how to choose the inductor (which is quite critical).
