I am powering my Arduino from standard 5V powerbank, and I want to measure its battery level by checking its voltage and sending it to arduino. I already made a circuit for it. Only thing I want to know is how is the voltage related to remaining charge in this case. For example, for 12 V battery it works like this: 12.73 V at 100% charge, 12.62 on 90% charge, 12.10 on 50% etc. How does this relationship work for 5V powerbank?
A power bank contains a boost converter that keeps output voltage at a steady 5volt until the battery is dead.
No way of knowing battery voltage unless you attach a wire to the actual battery and bring it outside the case.
Leo..
Which is a useful mod for such a powerbank, just make use to use a series resistor to prevent
accidentally shorting the LiPo battery and starting a fire, and don't solder onto the cell directly(!)
OK. When I disassemble it, how can I measure battery level then? Its about 4.8 V now, powerbank LED shows 75% charge. What is the relationship between charge and voltage?
The problem is that you are assuming that there is a relationship. Battery technologies differ and how they change while losing charge depends on chemistry. Voltage is a result of the chemistry... but many modern batteries will give you an almost flat discharge voltage until nearly depleted. just checking Voltage, is therefore, not an ideal 'linear' indicator.
NuclearShaman:
Did you even read the first reply? If you're measuring the USB output, there isn't a relationship.
NuclearShaman:
Measure the voltage of the battery directly (via the positive and negative poles of the battery inside, not the 5V output). You should see a voltage up to 4.2V when the battery inside is fully charged. As @vinceherman showed with his image example, the voltage vs remaining capacity is very much related to the current draw or load of the cell around the time of measurement.
