5V Relay not switching with Arduino Uno R3
Please Help! The 5V Relay is not responding to Arduino. While the two LEDs (Connected to NC & NO of Relay) should light up alternately as per the code, actually only one LED (Connected to NC Terminal of Relay) changes state alternately from full ON to little dim. The Orange Wire of Relay is Pole, Green Wire is NC, Purple Wire is NO & Brown & Blue wires are for Coil. I individually checked the relay with Multimeter; the resistance between the coil wires read about 73 Ohms and there is continuity between Pole & NC terminals.
Here's the code:
SparkFun Inventor's Kit
Example sketch 13
RELAYS
  Use a transistor to drive a relay
  A relay is a electrically-controlled mechanical switch.
  It can control much more voltage and current than an Arduino pin
  (or the transistor included in your kit) can. If you want to use
  the Arduino to control a 120V bulb, coffee maker, or other high-
  power device, a relay is an excellent way to do that. Because
  the relay needs more power to switch than an Arduino pin can
  provide, we'll use a transistor to drive the relay in exactly
  the same way we used a transistor to drive a motor in circuit 12.
  A relay consists of a coil of wire, and switch contacts. When
  you apply power to the coil, it becomes magnetized, and pulls
  the switch contacts closed. Since the switch contacts are
  completely isolated from the Arduino, you can safely use a
  relay to control normally dangerous voltages (but please only do
  this if you already know how to safely work with high voltage!).
  The relay has three contact pins, COM (common), NC (Normally
  Closed), and NO (Normally Open). When the relay is turned off,
  the COM pin is connected to the NC (Normally Closed) pin. When
  the relay is turned on, the COM pin is connected to the NO
  (Normally Open) pin.
  This code is very simple - it turns the relay on for one second,
  and off for one second, the same as the blink sketch!
Hardware connections:
  Transistor:
    The transistor has three pins. Looking at the flat side with
    the pins down, the order is COLLECTOR, BASE, EMITTER.
    Connect the BASE pin through a 1K resistor to digital pin 2.
    Connect the EMITTER pin to GND.
  Relay coil:
    The relay has pins for a coil (which you use to control the
    relay), and contacts (which you connect to the device you'd
    like to switch). The top or bottom of the relay should have
    a symbol indicating the coil pins.
    Connect one side of the coil to the COLLECTOR pin
    on the transistor.
    Connect other side of the coil to 5V.
  Diode:
    The relay has a coil that you energize to close the switch.
    When you disconnect power from a coil, the coil will generate
    a voltage spike that can damage the transistor. This diode
    protects the transistor from the voltage spike.
    Connect the side of the diode with the band (cathode) to 5V
    Connect the other side of the diode (anode) to the COLLECTOR
    pin of the transistor.
  Relay contacts and LEDs:
    We'll use the relay contacts to turn LEDs on and off, but you
    can use them to switch almost anything on and off.
    Connect the COMMON side of the switch to a 330 Ohm resistor.
    Connect the other side of the above resistor to 5V.
    Connect the NC (Normally Closed) side of the switch to the
    positive (longer) leg of LED 1.
    Connect the NO (Normally Open) side of the switch to the
    positive (longer) leg of LED 2.
    Connect the negative sides (shorter leg) of both LEDs to GND.
This sketch was written by SparkFun Electronics,
with lots of help from the Arduino community.
This code is completely free for any use.
Visit http://learn.sparkfun.com/products/2 for SIK information.
Visit http://www.arduino.cc to learn about the Arduino.
Version 2.0 6/2012 MDG
const int relayPin = 2;	    // use this pin to drive the transistor
const int timeDelay = 1000; // delay in ms for on and off phases
// You can make timeDelay shorter, but note that relays, being
// mechanical devices, will wear out quickly if you try to drive
// them too fast.
  pinMode(relayPin, OUTPUT);  // set pin as an output
  digitalWrite(relayPin, HIGH);  // turn the relay on
  delay(timeDelay);              // wait for one second
  digitalWrite(relayPin, LOW);   // turn the relay off
What happens when you energise the coil straight from a battery with the Arduino totally out of the test?
Presumably you have the transistor in between the Arduino and the relay coil?
Can you please post a copy of your circuit, in CAD or a picture of a hand drawn circuit in jpg, png or pdf?
We need to see how you have connected it to the arduino, and how you have connected the LED and their supply.
Thanks.. Tom..... :slight_smile:
Your relay seems to be pulling more current than the supply can produce, so that the
LED dims when the relay is switched - not enough current flows to move the
contacts, but its enough to pull the supply voltage down and dim the LED.
Do you have ratings for the relay and what transistor are you using? What's
the circuit? What's the power source? You know you have to use a
free-wheel diode I presume (vital to preventing damage).
Hi Everyone,
Now everything Working OK. What I was doing wrong was that I connected the Diode IN4148 incorrectly in reverse manner as shown in the Circuit Diagram of Sparkfun Guide. When I connected it right everything is working fine with no overheating on Arduino part & LEDs blinking alternately as desired. I am attaching the JPEG of Sparkfun's incorrect circuit. The Schematic of Sparkfun Guide shows the correct Circuit.
Thanks for your sincere Support,
Tanmay
Ah, yes, that would do it! Hopefully the transistor survived without damage (semiconductors
can be degraded by overload, appear to work but not as well).
Hi Mark,
MarkT:
Can you clarify whether the Schematic I'm using now will not damage the transistor in long run. Can you elaborate your point please.
cadinvent:
Hi Mark,
MarkT:
I think that MarkT tells you is that if you connect some component on wrong place or change it the polarity (Or stuff like that), you might see smoke or that the component does not work well.....We make sure the connections we do before plug the power supply...
Regards :slight_smile:
Thanks Carlos. Things are clear to me now.
Regards
Tanmay
