5V signal to 12V relay using mosfet
Dear All,
Recently, I decided to check all proprietary home automation and go DIY using arduino.
Of course, problems, as all my relays are controlled using 12V signal and the arduino spits out 5V. Obviously, solution: MOSFET.
What I would love to find, but failed so far, is to find a MOSFET PCB with maybe 10 modules, addressable individually and placing an addressing latch in between. So, the arduino puts an address 'HIGH', the latch picks the right MOSFET, the latter 'closes' the 12V circuit for a fraction and the relay is switched.
Is this a good solution? Where do I find these things? Or am I not making any sense?
KR Hewi
What current does eash relay need? A couple of ULN2803 or ULN2003's might be sufficient - they could
be driven from 595 shift registers to reduce the number of Arduino pins needed.
the relays need a couple of mili amps, the solution and components you propose seem like a good way forward. Where would I get these?
A couple of mA at 12V?? - even reed relays only go down to 10mA or so. Where did you get these?
200 - 300 mA, is also a 'couple', of course.
The ULN2x03 series are PCB with transistors, I was thinking more in terms of MOSFET
Couple of TPIC6C595 (100ma sink/output) or TPIC6B595 (150mA sink/output) will let you control up to 16 12V relays with just 3 signals from Arduino. They are shift register with open drain Mosfet output, very easy to use.
CrossRoads:
Very neat
As OP hasn't indicated what current the relays are taking, apart from either a couple of mA or
I would be careful as to suggesting any particular device, at this point. The TPIC6C595 or TPIC6B595 suggested, are great devices but will die very quickly if his relays require 200-300mA.
Just a thought.
hewi:
I must remember to ask you for a couple of drinks some time!
MarkT:
Sure, but you might not be satisfied with 200-300 mOz.
CrossRoads:
perfect reply and solution, thank you so much
Get a ready made solution from Crossroads.
