5V to 3.3V serial conversion
I have a device that runs on 3v3 that I’m interfacing to the Arduino. Powering it is not a problem- I have separate regulator that draws from the 5V supply.
The issue is that the device has a couple of serial ports that I need to connect to the Arduino. Is a simple voltage divider (or a Zener/R combo) a quick and easy fix? Or a dodgy and unreliable practise?
Thanks, knowledge base! :slight_smile:
http://forums.parallax.com/forums/default.aspx?f=25&m=124837 talks to the conversion on the propeller chip which is a 3v3 chip.
Perfect, thanks! ;D
