5V to every button
Hi. I am controlling different LEDs with different buttons but I know that each button needs a source of 5 V but there is only one 5V pin on my arduino uno board. How do I make it so the 5V will go to each button. Thx!!! :slight_smile: :slight_smile:
Ethan :slight_smile:
You need more pins. You can use a small breadboard to do that.
Or if you want it more permanent, you can solder several wires to one.
See image:
THX GUYS!!! @LarryD and @jack wp :slight_smile: :slight_smile: :slight_smile:
But it's easier to connect the buttons to GND and use the internal pull up of the Arduino. It saves you all the extra pull downs you need now.
Huh?? Thx,
Ethan
EQOxx123:
Huh?? Thx,
Ethan
You get to Read about "INPUT_PULLUP"
https://www.arduino.cc/en/Reference/Constants
https://www.arduino.cc/en/Tutorial/DigitalPins
Ok. Thx @Runaway Pancake !!
Ethan :slight_smile: :slight_smile: :slight_smile:
this is a really good tut on switches
Gammon switches
Ill check it out. Thx @Hutkikz !!!
