hello, i am a newbie... i have a project which is called 5x5x5 led cube... and i am having problems in programming since i don't have a background in programming in arduino...then our prof said that it should be passed after 3 days... can someone please give me a copy of a code of it?
the components used is 74hc595...
it will be very much appreciated.
Well if you post the project link, we might be able to point you in the right direction, just out of curiosity.
here : 5x5x5 LED Cube Run on Arduino Uno : 6 Steps - Instructables
but in my place, there are no 74hc238 available so i have to use 74hc595. but there is no code yet
ennair16:
The code is on the last page of the instructable.
ennair16:
The code will not work with 74hc595. It was written for 74hc238.
74hc595 is a shift register and 74hc238 is a decoder. The code would have to be significantly re-written to use 74hc595. I do not think 3 days will be enough, even if you get lots of help here. The only way to change the code in 3 days will be for someone here to re-write the code for you. I do not think your prof would approve.
Suggest you find another led cube design that you have the components for. There must be some that use 74hc595.
Paul
i hope someone would help any random lights would do...if i only know how to program
