5x5x5 LED cube with 74HC595
Hello,
Does anyoneknow how to solve the problem?
I made a LED cube with 5x5x5.
I used the link below as the manual for my project:
when I want to compile the code, which can be downloaded on the webside, there is an error with:
Arduino: 1.8.3 (Windows 10), Board: "Arduino/Genuino Uno"
Led_cube-Programm:202: error: narrowing conversion of '1000' from 'int' to 'byte {aka unsigned char}' inside { } [-Wnarrowing]
exit status 1
option enabled in File -> Preferences.
the error occurs at this section of the code:
#include <avr/pgmspace.h> // allows use of PROGMEM to store patterns in flash
#define CUBESIZE 5
#define PLANESIZE CUBESIZE*CUBESIZE
#define PLANETIME 3333 // time each plane is displayed in us -> 100 Hz refresh
#define TIMECONST 10 // multiplies DisplayTime to get ms - why not =100?
// LED Pattern Table in PROGMEM - last column is display time in 100ms units
// TODO this could be a lot more compact but not with binary pattern representation
const unsigned char PROGMEM PatternTable[] = {
// blink on and off
B00000,B11000,B00110,B00000,B00000,   B00000,B11000,B00110,B00000,B00000,   B00000,B11000,B00110,B00000,B00000,   B00000,B11000,B00110,B00000,B00000,   B00000,B00000,B00000,B00000,B00000,10,
B00000,B00110,B11000,B00000,B00000,   B00000,B00110,B11000,B00000,B00000,   B00000,B00110,B11000,B00000,B00000,   B00000,B00110,B11000,B00000,B00000,   B00000,B00000,B00000,B00000,B00000,10,
B00010,B00100,B01000,B10000,B00000,   B00010,B00100,B01000,B10000,B00000,   B00010,B00100,B01000,B10000,B00000,   B00010,B00100,B01000,B10000,B00000,   B00000,B00000,B00000,B00000,B00000,10,
B10000,B01000,B00100,B00010,B00001,   B10000,B01000,B00100,B00010,B00001,   B10000,B01000,B00100,B00010,B00001,   B10000,B01000,B00100,B00010,B00001,   B00000,B00000,B00000,B00000,B00000,10,
// this is a dummy element for end of table (duration=0) aka !!!DO NOT TOUCH!!!
B00000, B00000, B00000, B00000, B00000,
B00000, B00000, B00000, B00000, B00000,0
Thx Daniel
One the first line of data in PatternTable, there is the number 1000, which will not fit within an 8-bit character. If you use a number of 255 or less it will compile, not sure what the effect on the program will be.
