can you help me with this project ?
i need some help with the layout of the LED CUBE , its components , its PCB layout and also its , code ![]()
i hope you can help me with this project .
I need some help with my 5x5x5 LED CUBE PROJECT, LED CUBE LAYOUT, PCB LAYOUT , and its components , also the codes , I need some help with this project
What can you do already?
Codes for the cube - you should be able to adapt the library at GitHub - MajicDesigns/MD_Cubo: LED Cube Library (hardware independent).
If you want help on the hardware you will need to explain what you have as already done as this question is too open at the moment.
@Shuichi0806, do not cross-post. Threads merged.
