6 axis robot with nema 23 ebay 420oz motors coding from scrach sub loop maybe?
// H-W Robot arm setup -------------------------------------------------------------------------------
// give it a name:
int CH1 = 6;//turn pulse               axis    1
int CH2 = 2;//big arm pulse            axis    2
int CH3 = 4;//little arm pulse         axis    3
int CH4 = 10;//rotate fore arm pulse   axis    4
int CH5 = 12;//tool rist               axis    5
int CH6 = 8;//tool twist               axis    6
int AIR = 33;//tool twist
int GRIP = 32;//tool twist
int buzz = A1;//Alarm buzzer
int CH1dir = 7;//base turn DIR
int CH2dir = 3;//Big Arm Up down Dir
int CH3dir = 5;//little arm Dir
int CH4dir = 24;// Rotate For arm Dir
int CH5dir = 28;//base turn DIR
int CH6dir = 9;//Big Arm Up down Dir
int CH1Count = 0;// Counters
int CH2Count = 0;
int CH3Count = 0;
int CH4Count = 0;
int CH5Count = 0;
int CH6Count = 0;
int accel = 0;
// the setup routine runs once when you press reset:
  Serial.println("AXIS-1=" + CH1Count);
  Serial.println("AXIS-2=" + CH2Count);
  Serial.println("AXIS-3=" + CH3Count);
  Serial.println("AXIS-4=" + CH4Count);
  Serial.println("AXIS-5=" + CH5Count);
  Serial.println("AXIS-6=" + CH6Count);
  // initialize the digital pin as an output.
  pinMode(CH1, OUTPUT);
  pinMode(CH1dir, OUTPUT);
  pinMode(CH2, OUTPUT);
  pinMode(CH2dir, OUTPUT);
  pinMode(CH3, OUTPUT);
  pinMode(CH3dir, OUTPUT);
  pinMode(CH4, OUTPUT);
  pinMode(CH4dir, OUTPUT);
  pinMode(CH5, OUTPUT);
  pinMode(CH5dir, OUTPUT);
  pinMode(CH6, OUTPUT);
  pinMode(CH6dir, OUTPUT);
  pinMode(AIR, OUTPUT);
  pinMode(GRIP, OUTPUT);
  pinMode(buzz, OUTPUT);
  digitalWrite(CH1dir, LOW);
  digitalWrite(CH2dir, LOW);
  digitalWrite(CH3dir, HIGH);// CHANGE DIR OF CH3 TO up
  digitalWrite(CH4dir, LOW);
  digitalWrite(CH5dir, LOW);
  digitalWrite(CH6dir, LOW);
  delay(10);
  // END PIN SETUP LIST ---------------------------------------------------------------------------------
  // MOVE AXIS OFF STOPS
  while (CH3Count < 301)
    if (CH3Count < 400) {
      digitalWrite(CH3, HIGH);   // turn the CH1 on (HIGH is the voltage level)
      delay(1);               // wait for a second
      digitalWrite(CH3, LOW);    // turn the CH1 off by making the voltage LOW
      delay(1);
      CH3Count++;  // Incress count by one
      if ((CH3Count > 50) && (CH3Count < 100)) {
        digitalWrite(CH2, HIGH);   // turn the CH1 on (HIGH is the voltage level)
        digitalWrite(CH2, LOW);    // turn the CH1 off by making the voltage LOW
      else {
        CH3Count++;  // one tick then brake While loop
  //END GET OFF STOPS ZERO COUNTERS----------------------------------------------------------------------
  CH2Count = 0;
  CH3Count = 0;
  CH4Count = 0;
  CH5Count = 0;
  CH6Count = 0;
  //debug print current vals as zero
  Serial.println("AXIS 1 ZERO");
  Serial.println(CH1Count);
  Serial.println("AXIS 2");
  Serial.println(CH2Count);
  Serial.println("AXIS 3");
  Serial.println(CH3Count);
  Serial.println("AXIS 4");
  Serial.println(CH4Count);
  Serial.println("AXIS 5");
  Serial.println(CH5Count);
  Serial.println("AXIS 6");
  Serial.println(CH6Count);
  //digitalWrite(AIR, HIGH); uncoment after debug to run air
  digitalWrite(GRIP, HIGH);
  delay(400);
  digitalWrite(GRIP, LOW);
  delay(400);
  digitalWrite(AIR, LOW);
  Serial.println("AXIS 1");
  //SQWEEZ GRIPS
void loop (){
  accel = 3000; //  set accel start of new move
  while (CH3Count < 1001)
       //ACELL -- DE-CELL BLOCK-=-=-=-=-=-==-=-=-=-=-=-=-=-=-=-=----=
    if ((CH3Count < 300) && (CH3Count > 0)){//de-accel
      accel--;
      accel--;
      accel--;
    else {
      if ((CH3Count > 300 ) && (CH3Count < 700)){//QUESTION RANGE
      accel = 1000;
    if ((CH3Count > 700) && (CH3Count < 1000)){
      accel++;
      accel++;
      accel++;
    else {
      if ((CH3Count > 300 ) && (CH3Count < 700)) {//QUESTION RANGE
      accel = 1000;
//END  ACELL -- DE-CELL BLOCK-=-=-=-=-=-==-=-=-=-=-=-=-=-=-=-=----=
    if (CH3Count < 1000) {
      delayMicroseconds(accel);// wait for a second;
      // accel--;
      CH3Count++;  // incress count one tick
      //accel--;
    else {
  }//  End Of Move<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
//NEW MOVE CH2 >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
  accel = 3000; //  set NEW accel start of new move  OR MOVE WILL BE LAST
  while (CH2Count < 2501)
    if ((CH2Count < 200) && (CH2Count > 0)){//de-accel  IF POS IS ALL-MOST AT ZERO
      accel--;
      accel--;
      accel--;
    else {
      if ((CH2Count > 400 ) && (CH2Count < 600)){// CENTER RANGE OF CONSTANT SPEED
      accel = 1000;
    if ((CH2Count > 600) && (CH2Count < 1000)){ //ACCELL  IF POS IS GRATER THEN VAL
      accel++;
      accel++;
      accel++;
    else {
//END  ACELL -- DE-CELL BLOCK-=-=-=-=-=-==-=-=-=-=-=-=-=-=-=-=----= SEET MOTOR MOVMENTS AND POS
    if (CH2Count < 1000) {
      // accel--;
      CH2Count++;  // incress count one tick
      //accel--;
    else {
      CH2Count++;  // one tick then brake While loop
  //  End Of Move
  while (CH2Count < 1001)
      accel--;
      accel--;
      accel--;
    else {
      accel = 1000;
      accel++;
      accel++;
      accel++;
    else {
      // accel--;
      //accel--;
    else {
  //  End Of Move
// reverse to zero
set up
is 6 tb6560 drivers 24 v 3.0 amp
Is there a question ?
...R
Robin yes ... I'm sorry it was in the subject ..
Trying to Control the beast with less programming .. like single sub loop that i could keep calling out under different conditions ...
like i put this bit together have not reduced the garbage lines out yet ...
  while (CH3Count < 1001)//  <<< this forced the conditions to be true
    if ((CH3Count < 300) && (CH3Count > 0)){  //de-accel  argument
      accel--;// accel being an INT variable called out in the setup as index-able acceleration counter
      accel--;// allowing me to use the times thru the loop
      accel--;//thus using the returned val as a value for pulse delay
    else {
      if ((CH3Count > 300 ) && (CH3Count < 700)){//then a none accel or de-cell mid RANGE of steps
      accel = 1000;
      accel++;
      accel++;
      accel++;
    else {
// think this else is a repeated logical argument that may not be necessary but does not hurt it
      accel = 1000;
   }//END  ACELL -- DE-CELL BLOCK-=-=-=-=-=-==-=-=-=-=-=-=-=-=-=-=----=
so what if i could reduce this to a sub loop or some thing that i could call out 3 of the values manual in the ladder of the main progran and then return to this loop for accel and de-accel reasons ...
i looked that the accela stepper a bit that seems to be where i was going with it but it seems like that library is to limited for my 6-axis use
I'm sorry to say I don't understand what your code snippet is trying to do or your description.
Also I have no idea of your programming experience.
If you want to create a responsive program you should not be using WHILE because that blocks the Arduino until it completes. Almost certainly you will want all the motors to be able to move at the same time.
When you use the words "sub loop" do you mean a function? I am a great believer in dividing code into small functions that can be tested separately and called multiple times.
Maybe you would get some ideas from Planning and Implementing a Program
...R
