6 Buttons 2 pins problem
Hello some where online a while back i found online a way to do 6 push buttons and only need 2 pins but i didn’t get around to it into now. i saved the sketch and how it was wired up but when i go to try it doens’t work i get all zeros from it. just going and going i lost the link to the page so i can’t find it no where can someone please help me with this sketch i have no clue why it is not responding
int old_button = 0;
int button;
int pressed_button;
int z;
void setup () {
  pinMode(A5, INPUT);
void loop () {
  z = analogRead(5);
  if (z > 1021) button = 0;
  else if (z > 511 && z < 514) button = 1;
  else if (z > 680 && z < 684) button = 2;
  else if (z > 766 && z < 770) button = 3;
  else if (z > 817 && z < 822) button = 4;
  else if (z > 851 && z < 856) button = 5;
  else if (z > 875 && z < 880) button = 6;
  else button = 0;
  if (old_button == button) {
    old_button = button;
    pressed_button = 0;
  else {
    pressed_button = button;
  Serial.println(pressed_button);
You need a ladder of resistors and buttons. That circuit is okay.
Why don’t you use a simple sketch to check the analog value and the button value ?
cont int pinAnalogButtons = A5;
void setup () {
  Serial.println("Started");
void loop () {
  int button;
  int z = analogRead(pinAnalogButtons);
  Serial.print("value=");
  Serial.println(z);
  else button = 0;
  Serial.print("button=");
  Serial.println(button);
  delay(1500);
If it is not working, check all the voltages with a multimeter.
Hello peter I'm not sure i never used push buttons like this not even sure how to do them. i can do a single push buttons with a simple turn on and off led but that is all m first time trying this. i tried your sketch and this is what i got.
Arduino: 1.6.5 (Windows 8.1), Board: "Arduino Uno"
sketch_sep11a.ino:2:1: error: 'cont' does not name a type
sketch_sep11a.ino: In function 'void loop()':
sketch_sep11a.ino:11:22: error: 'pinAnalogButtons' was not declared in this scope
Error compiling.
This report would have more information with "Show verbose output during compilation" enabled in File > Preferences.
Oops, sorry, :-[ It must be "const", not "cont".
Thank you peter for the help it is working. Now just got to figure out with pushing the button it will turn on a led.
