6 capacitance sensors-- problem with sample code?
I am working on making a keypad with 6 capacitance sensors. I am using an arduino diecimilia. I tried using the sample code found here: arduino.cc/playground/Code/CapacitiveSensor
The problem is no matter what is touching it, input digital 13 always returns a value of 16 in the serial output.
Does anyone have any ideas why this might be the case?
Thank you so much!!!!
Note: I'm also named Mario, but I'm not the person who wrote the sample code below.
Mario Becker, Fraunhofer IGD, 2007
// sensor key
#define KEYPORT PORTB
#define KEYDDR DDRB
#define KEYPIN PINB
#define KEY0 PB0 // capture input - digital 8
#define KEY1 PB1 // capture input - digital 9
#define KEY2 PB2 // capture input - digital 10
#define KEY3 PB3 // capture input - digital 11
#define KEY4 PB4 // capture input - digital 12
#define KEY5 PB5 // capture input - digital 13
Serial.begin(9600); // connect to the serial port
// returns capacity on one input pin
// pin must be the bitmask for the pin e.g. (1<<PB0)
char getcap(char pin)
char i = 0;
KEYDDR &= ~pin; // input
KEYPORT |= pin; // pullup on
for(i = 0; i < 16; i++)
if( (KEYPIN & pin) ) break;
KEYPORT &= ~pin; // low level
KEYDDR |= pin; // discharge
return i;
void loop ()
char capval[6];
char pinval[6] = {1<<KEY0,1<<KEY1,1<<KEY2,1<<KEY3,1<<KEY4,1<<KEY5};
for(char i = 0; i < 6; i++)
capval = getcap(pinval*);*
* Serial.print("digital ");*
* Serial.print(i+8, DEC);*
* Serial.print(": ");*
_ Serial.println(capval*, DEC);
Serial.println("");
}*_
Hey,
I'm trying to do the same and keep getting the same problem. Unfortunately, I've had to delete pin13 and lower the array to five. It works with five sensors but the problem is niggling me. I don't suppose you have any idea of how to get this code to communicate with max/msp? I've downloaded the Arduino2Max patch from the Arduino site and technically it should be reading the values outputted from Arduino but alas, no.
Any ideas or suggestions?
Thanks
