6 inputs with Arduino and Output on 7 segment display
hi ,
I would like to know if I can make the above subjective circuit / project which have Multi Switch's [ 6 inputs (Call Switch's)] for Arduino and display its respective input on 7 segment display as Output. and an RESET Switch to mark as Attended...
say 1 , 2 , 3 , 4 , 5 , 6 , (0 as Reset as and when Reset Switch is pressed)
Please help
I really cannot answer that question as asked because I do not know your skills or resources. If you are asking can it be done, yes it can. Why not make a schematic, not a frizzy picture of your preliminary design with a start on the software. From that point we should be able to get you going. There are several posts with variations of your requirements posted but I did not see any that do exactly what you want.
So you have;
7 buttons numbered 0, 1, 2, 3, 4, 5, 6
A 7 segment display as output, displaying the value of each button as it is pushed.
Yes it is possible, what model Arduino do you have?
Does it have enough input/output pins.
7 input and 7 output pins will be required.
If not enough pins available, there are methods to use a limited number of I/O.
What 7 segment display do you have, common anode or common cathode?
Looking at your history, you have written code before, so to start write some code that reads each of your 6 buttons and uses Serial monitor to show what button is pressed?
Thanks.. Tom... :smiley: :+1: :coffee: :australia:
