Hello everyone reading this post, thanks for taking the time!
Question: Is it possible to have a board acting as a arduino uno (but smaler size) to handle 6 TOF sensors and an accoustic sensor and write this to a SD-card? pref. in a format i can later compile into a pointcloud
i am trying to make a 3d map of a pipeline where each sensor is covering 60* degrees rotating back and fourth on a servo ( the one i have been experimenting with is a Mg90S tower 180*, and able to make about one pass every 0.5 seconds)
and i was thinking about using an accelerometer to calculate distance in between each pass.
so i can get x,y,z direction for a pointcloud)
but is it even possible to get all this data into a smaller chipset arduino unit? supplied with a 12v battery?
edit1: is it possible to translate code and pinout onto a arduino nano board?
edit2: is there any boards small or larger with bigger memory than A.uno? as i am having some issues using about 75% of current capacity
Take a look at the Adafruit feather range. It's about the same size as a Nano, you can power it off a LiPo battery, it's faster and has more memory. There's one with a slot for MicroSD too.
wildbill:
thanks for the reply, i will check those boards out, but how's the coding to that compared to the uno? as i am a newbie when it comes to programing (self taught) and just learning the arduino language and a little C++
I have not used a feather, but they can be programmed using the Arduino IDE just as if it were any other Arduino. You can apparently use Micropython as an alternative too.
There's a few caveats on their site, but for the most part you can just consider it a supercharged nano as far as I can see.
wildbill:
How many pins do you need for each ToF sensor?
ahh ok, well that sounds perfect.
well i need SDA,SCL on all but with X-shut in between each reading.
aswell as GND and power
so 5 pins for each, but i guess 4 can be shared ? (SDA,SCL,Power,GND)
and power,gnd, digital pin for servo
