60 led-strips driver
I want to drive 60 monochromatic led strips (5w each).
A starting point would be using 74HC595 shift registers to control 72 mosfets.
I found this board http://www.elcojacobs.com/using-shiftpwm-to-control-led-strips-with-arduino/ to do exactly this with tree of them.
But anybody knows if there are IC's that could do the same ?
The Texas Instruments TLC5940 chip will do 12-bit PWM on 16 current-controlled outputs:
It can sink up to 17V (0-120 mA) so you can put a bunch of LEDs in series. Four of them will give you 64 channels.
The LED strips are typically 3 LEDs in series with a current limit resistor designed to run from 12V - a long strip will have many 3-LED segments in parallel, with each segment needing ~ 20mA. Plan accordingly.
johnwasser:
True, but it's a current sink so it makes driving MOSFETs much more complex than it needs to be.
Lucamarkio:
I'm guessing they're 12V strips.
5W means 0.416 amps per strip, that's 60 LEDs.
I don't think there's an IC that can do half an amp on each pin... you'll need the MOSFETs.
Yup - even tpic6a595 only does 350mA continuous.
tpic6a595.pdf (575 KB)
Johnwasser,
your solution seems nice, I'm looking at the datasheet and I see I can connect multiple ICs in series,
however 120mA is not enough since I need to power one 5w led strip on each IC output. As fungus said that would be 416mA on each pin( and I need 60 of them)
350mA is too risky for my application.
If there's no ICs for that I should definitely go with a board like the one in my first post ( 74HC595 + MOSFETS ) . Unfortunately that board is not available, do some of you can help providing or finding something similar and readily available?
Lucamarkio:
Johnwasser,
How are the LEDs in the 'strip' wired? How many LEDs? Voltage drop across each? Current limiting resistors? Supply voltage?
To drive MOSFETs with the TLC5940's open-collector outputs can't you just add a pull-up resistor to each Gate?
johnwasser:
LED in the strip are wired exactly as CrossRoads explained.
Im dealing with 100cm pieces of these strips http://www.entityel.com/datasheets/1300ENSTRIP5-120.pdf ( 60 of them)
johnwasser:
If I were to manually solder 60 mosfet I would go with eight 74HC595 ( like the board linked in my firs post ).
I'd like to find an IC that saves me some time
This is the work i’ve done last summer… and that I want to avoid redoing with 3 times the outputs
back view
Lucamarkio:
I’m dealing with 100cm pieces of these strips http://www.entityel.com/datasheets/1300ENSTRIP5-120.pdf ( 60 of them)
If a full 5M strip draws <=48W@12V that’s <=4A. Each of the 200 3-LED segments (2.5cm) draws 20 mA. Your 100 cm (1 M) segments should draw 800 mA (9.6W @ 12V).
What made you think your strips were 5W?
Looks like you're ready for a PCB. How soon do you need this?
johnwasser:
You’re right :cold_sweat:
I need to verify this thing. Either they gave me the wrong datasheet or they told me b******t. The right datasheet is probably http://www.entityel.com/datasheets/1300ENSTRIP5.pdf
CrossRoads:
Looks like you’re ready for a PCB. How soon do you need this?
ASAP, I’d say yesterday!
That’s not very good planning then 8)
The picture you posted, that’s just daisychained 74HC595s driving N-channel MOSFETs with 2-screw terminal per strip, one the MOSFET open drain and the other +12V?
CrossRoads:
That's not very good planning then 8)
The picture you posted, that's just daisychained 74HC595s driving N-channel MOSFETs with 2-screw terminal per strip, one the MOSFET open drain and the other +12V?
Exactly!
The picture lacks a power plug but basically in the first picture on the left you can see two long leads crossing, that's the power input .
It's quite a generic circuit, also the board i posted at the beginning of this thread is almost identical. How is it possible I cannot find a similar board in production?
With 60 drivers? I expect it would be somewhat unique.
What about an 8 output module ? I could combine them to make 8x8 = 64 outputs.
So maybe 2 boards like this, daisy chained together.
