64 channel multiplexer with read and write
Hello,
I am trying to develop a 64-channel multiplexer board with both read and write options for each channel so that at the end I can inject current through one and reach voltage from the other. I wish to control it using a nano by SPI. I use ADG731 and ADG738 ICs (datasheets in attachment), where I use two 731s ([32:1] x 2) in conjunction with ADG819 [2:1] mux for reading output from a channel. On the otherhand, I use eight 738s ([8:1] x 2) for writing into a channel. Now, when I code the nano as shown below, I observe that all my channels show the same output when I try to read, whilst I code to only use one switch. The same thing is happening to read as well.
#include <SPI.h>
#define sclkPin 13
#define sync_u1 2
#define sync_u2 12
#define adg819_in 7
#define mosiPin 11
#define sync_write A5
#define reset_ic1 A0
#define reset_ic2 A1
#define reset_ic3 A2
#define reset_ic4 A3
#define reset_ic5 3
#define reset_ic6 4
#define reset_ic7 5
#define reset_ic8 6
int readEnabled = 0;
int writeEnabled = 0;
SPI.begin();
pinMode(mosiPin, OUTPUT);
pinMode(sclkPin, OUTPUT);
pinMode(adg819_in, OUTPUT);
pinMode(sync_write, OUTPUT);
digitalWrite(sync_write, HIGH);
pinMode(sync_u1, OUTPUT);
digitalWrite(sync_u1, HIGH);
pinMode(sync_u2, OUTPUT);
digitalWrite(sync_u2, HIGH);
pinMode(reset_ic1, OUTPUT); // TODO: set output it for all reset pins connected
digitalWrite(reset_ic1, LOW); // TODO: set high it for all the reset pins connected
pinMode(reset_ic2, OUTPUT);
pinMode(reset_ic3, OUTPUT);
pinMode(reset_ic4, OUTPUT);
pinMode(reset_ic5, OUTPUT);
pinMode(reset_ic6, OUTPUT);
pinMode(reset_ic7, OUTPUT);
pinMode(reset_ic8, OUTPUT);
delay(10);
disable_all();
enable_write(64);
// TODO: What interface is needed here?
// I’m providing some functions to interface the pogo pins → disable_all, enable_read, enable_write
void _switch_u1_u2(int pinNumber, bool u1)
if (u1)
digitalWrite(sync_u1, LOW);
digitalWrite(sync_u2, LOW);
if(pinNumber > 32 || pinNumber < 1)
SPI.transfer(1 << 7); // Switches off all the pins
SPI.transfer(pinNumber - 1);
if (u1)
delay(10);
void _switch_writer_ic(int switchNumber, int icNumber)
digitalWrite(sync_write, LOW);
SPI.transfer(1 << switchNumber);
if (icNumber == 0)
digitalWrite(reset_ic1, HIGH);
if (icNumber == 1)
digitalWrite(reset_ic2, HIGH);
if (icNumber == 2)
digitalWrite(reset_ic3, HIGH);
if (icNumber == 3)
digitalWrite(reset_ic4, HIGH);
if (icNumber == 4)
digitalWrite(reset_ic5, HIGH);
if (icNumber == 5)
digitalWrite(reset_ic6, HIGH);
if (icNumber == 6)
digitalWrite(reset_ic7, HIGH);
if (icNumber == 7)
digitalWrite(reset_ic8, HIGH);
delay(10);
void _disable_read()
SPI.transfer(1<<6);
readEnabled = 0;
delay(10);
void _disable_write()
digitalWrite(reset_ic2, LOW);
digitalWrite(reset_ic3, LOW);
digitalWrite(reset_ic4, LOW);
digitalWrite(reset_ic5, LOW);
digitalWrite(reset_ic6, LOW);
digitalWrite(reset_ic7, LOW);
digitalWrite(reset_ic8, LOW);
writeEnabled = 0;
delay(10);
void disable_all()
_disable_write();
_disable_read();
void enable_read(int pinNumber)
if(writeEnabled == pinNumber)
Serial.println(String("Pin “) + pinNumber + " already in write mode, cannot enable read”);
delay(10);
return;
else if(readEnabled > 0)
_disable_read();
if (pinNumber < 1 || pinNumber > 64)
Serial.println(“Valid pin number between 1 and 64 needed”);
else if (pinNumber > 32)
_switch_u1_u2(pinNumber-32, false);
digitalWrite(adg819_in, HIGH);
_switch_u1_u2(pinNumber, true);
digitalWrite(adg819_in, LOW);
readEnabled = pinNumber;
delay(10);
void enable_write(int pinNumber)
if(readEnabled == pinNumber)
Serial.println(String("Pin “) + pinNumber + " already in read mode, cannot enable write”);
delay(10);
return;
else if(writeEnabled > 0)
_disable_write();
int icNumber = pinNumber >> 3; // divide by 8
int switchNumber = pinNumber & 0x7; // last 3 bits
_switch_writer_ic(switchNumber, icNumber);
writeEnabled = pinNumber;
delay(10);
ADG725_731.pdf (258 KB)
ADG738_739.pdf (345 KB)
Mod.txt (4.15 KB)
Why do you assume that you have a coding problem? Perhaps it is a wiring problem.
Your code was small enough to post inline.
IN CODE TAGS!
