64+ inputs in Arduino
I am working on a project but I will need more than 70+ inputs and also being able to read them simultaneously and send them wirelessly. I have an arduino uno and I was wondering if it is possible to built such a system with the hardware that I have?
Analog or digital?
Nothing happens simultaneously. What is your real requirement?
How is this relevant?
Depends on details you haven't provided.
PaulS:
Analog or digital?
Well from analog or digital I would choose the one that allows me to have more inputs. As for the other question, most of them are note relevant you are right. My requirement is to gather input from 64+ buttons as they happen very fast. Like reading a keyboard keypresses!
A switch is a digital device. It is either on or off.
A potentiometer is an analog device. It can return a range of values.
You don't just randomly choose one. You use multiplexers of the appropriate kind, based on the type of device providing the input.
My keypresses are not fast at all. Except for the backspace key. I use it a lot.
You can capture the state of as many digital inputs at one time as you want by having them connected to parallel/serial shift registers.
Use 1 Latch/clock pin to capture all inputs at one time, then SPI.transfer()s to move the string as bytes into an array, and send out the array.
On the other hand, if you want a keypad, then the keypad.h library will support a 72-button keypad with 17 pins, or 81-button keypad with 18 pins.
PaulS:
Thanks for the information. I will go for digital. Now is there any way to connect 64+ buttons to an arduino?
CrossRoads:
74HCT597N,652 NXP USA Inc. | Integrated Circuits (ICs) | DigiKey Marketplace
Thanks! That was very useful!
Regarding this keypad you are talking about, is it something that already exists (you built or acquired it) or is it just a plan? Multiplexing requires the keys to be connected a certain way in a matrix.
