6V 20A power supply for arduino robotic arm project
Hello everyone!
I am working on the control of a robotic arm using Arduino Uno. I have four Tower Pro MG995R servo motors, each has a stall current 2.5A. So this means that i should supply 10A for my project. I have a power supply of 6V 20A and want to externally power the servos using it. Please guide how it can be done? how circuit can be made? what wires to use? how to connect different components like Arduino potentiometers encoders so all are safe with such power supply? can breadboard be used? Kindly have your views.
Thanks.
It wiil be safe
No breadboards.
Jumpers must be short
Make sure that ALL grounds (GND) are connected
Your other topic on the same subject deleted.
Please do not duplicate your questions as doing so wastes the time and effort of the volunteers trying to help you as they are then answering the same thing in different places.
Please create one topic only for your question and choose the forum category carefully. If you have multiple questions about the same project then please ask your questions in the one topic as the answers to one question provide useful context for the others, and also you won’t have to keep explaining your project repeatedly.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum
Thank you.
Directly connecting a 6V 20A power to four servo motors...will servo wires handle this? and if i can not use breadboard how can i connect arduino, potentiometers, encoders and robotic arm?
Unless the manufacturer of the servos gave you cheap wires, we have to assume they can handle the curent.
You can use the breadboard for low current things like pots, encoders, push buttons, single LEDs and the servo signal but NOT for the servo power.
The servo power power should be connected diretly from the power supply to the servos.
Don't forget that all grounds(GND) should be connected together.
