Hello. I am fairly new at Arduino and coding in general. My project is an alarm system that when, a button is pressed, begins a countdown on a 7 bit display and when the countdown gets to 0, a very annoying sound blares from the active buzzer. My current code is below this small paragraph and i have marked up a diagram of the 7 bit display in the attachments (i cant be bothered with diagraming it all myself).(btw the box with the red circle in it is the buttons and the black circle with the gray circle inside it is the buzzer). The problem is that once i press the button, the countdown gets stuck at 9 and does not go any further.
thanks
CODE:
int buzzer = 12;//the pin of the active buzzer
byte seven_seg_digits[10] = { B11111100, // = 0
B01100000, // = 1
B11011010, // = 2
B11110010, // = 3
B01100110, // = 4
B10110110, // = 5
B10111110, // = 6
B11100000, // = 7
B11111110, // = 8
B11100110 // = 9
int latchPin = 3;
int clockPin = 4;
int dataPin = 2;
int button = 9;
// Set latchPin, clockPin, dataPin as output
pinMode(latchPin, OUTPUT);
pinMode(clockPin, OUTPUT);
pinMode(dataPin, OUTPUT);
pinMode(buzzer,OUTPUT);
pinMode(button, INPUT_PULLUP);
void sevenSegWrite(byte digit) {
digitalWrite(latchPin, LOW);
shiftOut(dataPin, clockPin, LSBFIRST, seven_seg_digits[digit]);
digitalWrite(latchPin, HIGH);
if (digitalRead(button) == LOW){
for (byte digit = 10; digit > 0; -- digit) {
sevenSegWrite(digit - 1);
unsigned char i;
while(1)
if (digit==0){
digitalWrite(buzzer,HIGH);
delay(1);//wait for 1ms
digitalWrite(buzzer,LOW);
delay(100);
Please reply with a solution
