I have a problem regarding my 7 in 1 soil sensor but i dont know if this is product defect or in coding itself. To understand further about my problem please watch my video till end so you can see my serial monitor output (2023-09-07 02-13-02.mkv - Google Drive)
Here is the code i used
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3); // RX, TX
mySerial.begin(4800); // NPK communicates at 4800 bps
byte queryData[] {0x01,0x03,0x00,0x00,0x00,0x07,0x04,0x08};
byte receivedData[19];
mySerial.write(queryData,sizeof(queryData)); // send query data to NPK
delay (1000);
if (mySerial.available() >= sizeof(receivedData)) { // Check if there are enough bytes available to read
mySerial.readBytes(receivedData, sizeof(receivedData)); // Read the received data into the receivedData array
// Print the received data in HEX format
for (int i = 0; i < sizeof(receivedData); i++) {
Serial.print(receivedData[i], HEX);
Serial.print(" ");
im not sure also if all 7 in 1 soil sensors from different manufacturers have the same inquiry frame especially for those branded 7 in 1 soil sensor and imitation. Also the output from the youtuber that i used as reference of the code is having good output (https://www.youtube.com/watch?v=nGvaAZSIQaA). I hope someone can help me
