7" SDD1963 TFT inverted display on horizontal axis
my 7" tft works but the horizontal axis is inverted. displays back to front.
could someone please shed some light on the issue.
I am using the following parts
Arduino Mega 2560 R3
7.0" inch TFT LCD module 800x480 with SSD1963 driver chip http://www.ebay.com.au/itm/7-7-0-inch-TFT-LCD-module-Font-IC-800x480-SSD1963-arduino-DUE-MEGA2560-3-5-4-3-/171081404490?pt=LH_DefaultDomain_0&hash=item27d53f104a&_uhb=1
TFT/SD Shield for Arduino MEGA http://www.ebay.com/itm/TFT-SD-Shield-for-Arduino-MEGA-2560-LCD-Module-SD-level-translation-2-8-3-2-DUE-/121161179201?pt=LH_DefaultDomain_0&hash=item1c35c4e041
I have downloaded the newest arduino IDE (Arduino 1.0.5) and UTFT library (2.51) Using the UTFT library i load the default UTFT_Demo_800x480 Sketch. I then change the lcd model to UTFT myGLCD(CTE70,38,39,40,41); Compiling this returns an error: 'CTE70' was not declared in this scope. I then changed the model name from CTE70 to SSD1963_800 : UTFT myGLCD(SSD1963_800,38,39,40,41); This works and the display comes on with the image but does not work correctly. The display is inverted on the horizontal axis. All the text and images are displayed back to front. The touch coordinates are also inverted.
i have tried some workarounds from a few forums but just cant seem to get it to work.
any help would be highly appreciated
regards ewan
i am not sure what the problem is, but i am using 1.5.2 version of the IDE.
here is the same demo, and it compiled fine on my IDE with the “board” set to the mega.
// Demo with Font and icon Flash IC
// (C) 2013 Coldtears electronics
// For use with  CTE 7.0" (800x480) LCD Module w/Font and Icon Flash IC
// in combination with CTE TFT/SD Shield for Arduino MEGA2560
// web: http://stores.shop.ebay.com/coldtears-electronics-store
// The first part of the demo is to show how to use the font IC to draw font to the LCD,
// The IC also include some commonly used and open source icons
// great for custom application development.
// Second part of the demo code is adapted from Henning Karlsen's demo
// Original by
// UTFT_Demo_800x480 (C)2012 Henning Karlsen
// web: http://www.henningkarlsen.com/electronics
// This demo was made for modules with a screen resolution
// of 800x480 pixels.
// This sketch requires the UTFT library by Henning Karlsen
// also requires the Flash_IC library by Coldtears electronics
#include <UTFT.h>
#include <UTFT_CTE.h>
#include "SPI.h"
extern uint8_t SmallFont[];
// Set up UTFT for CTE70 on Arduino Mega
UTFT_CTE CTE_LCD(&myGLCD);
  myGLCD.InitLCD();
  myGLCD.setFont(SmallFont);
  myGLCD.setBackColor(VGA_BLACK);
  CTE_LCD.SPI_Flash_init(FLASH_CS_PIN);
  CTE_LCD.show_color_bar();
  myGLCD.clrScr();
  CTE_LCD.Load_image(0,0,287);
  myGLCD.setColor(255, 222, 111);  //Set font color
  myGLCD.setBackColor(0, 0, 0);  //Set background color
  CTE_LCD.Set_character_spacing(1);
  CTE_LCD.Put_Text("Coldtears electronics",5,400,BVS_34);
  CTE_LCD.Put_Text("TFT LCD w/Font IC Demo",5,440,BVS_34);
  myGLCD.clrScr();
  CTE_LCD.Set_character_spacing(3);
  CTE_LCD.Put_Text("Coldtears electronics",10,5,BVS_34);
  myGLCD.setColor(166, 256, 211);  myGLCD.setBackColor(0, 255, 0);
  CTE_LCD.Put_Text("5.0/7.0 TFT LCD Module w/Font IC Demo",10,40,BVS_22);
  myGLCD.setColor(255, 255, 255);  myGLCD.setBackColor(0, 0, 0);
  CTE_LCD.Put_Text("123456789",10,65,BVS_15);
  myGLCD.setColor(0, 255, 255);
  CTE_LCD.Put_Text("abcdefg",10,80,BVS_34);
  myGLCD.setColor(255, 255, 0);
  CTE_LCD.Put_Text("hijklmnopgrstu",10,115,BVS_43);
  myGLCD.setColor(122, 122, 122);
  CTE_LCD.Put_Text("12345789",10,165,BVS_52);
  myGLCD.setColor(122,255, 255);
  CTE_LCD.Put_Text("!@#$%^&*()",10,217,BVS_52);
  myGLCD.setColor(255,0, 255);
  CTE_LCD.Put_Text("ABCDEFGHIJKLMNO",10,269,BVS_74);
  myGLCD.setColor(255,255, 255);
  CTE_LCD.Put_Text("PQRSTUVWXYZ",10,343,BVS_112);
  myGLCD.clrScr();
  static char buff[33];
  for(unsigned char temp=32; temp<65; temp++)  { buff[temp-32]=temp; }  buff[33]=0;
   CTE_LCD.Put_Text_array(buff,0,0,BVS_52);
  for(unsigned char temp=65; temp<92; temp++)  { buff[temp-65]=temp; }  buff[27]=0;
  CTE_LCD.Put_Text_array(buff,0,60,BVS_52);
  for(unsigned char temp=92; temp<127; temp++)  { buff[temp-92]=temp; }  buff[33]=0;
  CTE_LCD.Put_Text_array(buff,0,120,BVS_52);
  for(unsigned char temp=127; temp<154; temp++)  { buff[temp-127]=temp; }  buff[27]=0;
  CTE_LCD.Put_Text_array(buff,0,180,BVS_52);
  for(unsigned char temp=154; temp<181; temp++)  { buff[temp-154]=temp; }  buff[27]=0;
  CTE_LCD.Put_Text_array(buff,0,240,BVS_52);
   for(unsigned char temp=181; temp<204; temp++)  { buff[temp-181]=temp; }  buff[23]=0;
  CTE_LCD.Put_Text_array(buff,0,300,BVS_52);
  for(unsigned char temp=204; temp<227; temp++)  { buff[temp-204]=temp; }  buff[23]=0;
  CTE_LCD.Put_Text_array(buff,0,360,BVS_52);
   for(unsigned char temp=227; temp<255; temp++)  { buff[temp-227]=temp; }  buff[27]=0;
  CTE_LCD.Put_Text_array(buff,0,420,BVS_52);
unsigned int k=2,location=1;
while(k>0)
  myGLCD.clrScr();
  for (unsigned temp1 =0; temp1<11; temp1++)
    for (unsigned temp2 =0; temp2<18; temp2++)
      CTE_LCD.Load_image(temp2*44,temp1*44,location);
      location++;
      if(location==236) break;
  k--;
myGLCD.clrScr();
CTE_LCD.Put_Text("Countdown for LCD Display",0,0,BVS_74);
CTE_LCD.Put_Text("Demo by Henning Karlsen",0,75,BVS_74);
myGLCD.setColor(150, 222, 255);
k=50;
while(k>0)
  k--;
  String test_string = String(k);
  test_string = "000"+ test_string + "       ";
  CTE_LCD.Put_Text(test_string,200,210,BVS_112);
  int temp;
  if (k%3==2) temp=275;  else if (k%3==1) temp=277;  else temp=279;
  CTE_LCD.Load_image(50,400,temp); CTE_LCD.Load_image(150,400,temp+6);
  delay(100);
int buf[798];
  int x, x2;
  int y, y2;
  int r;
// Clear the screen and draw the frame
  myGLCD.clrScr();
  myGLCD.setColor(255, 0, 0);
  myGLCD.fillRect(0, 0, 799, 13);
  myGLCD.setColor(64, 64, 64);
  myGLCD.fillRect(0, 466, 799, 479);
  myGLCD.setBackColor(255, 0, 0);
  myGLCD.print("* Universal Color TFT Display Library *", CENTER, 1);
  myGLCD.setBackColor(64, 64, 64);
  myGLCD.setColor(255,255,0);
  myGLCD.print("<http://electronics.henningkarlsen.com>", CENTER, 467);
  myGLCD.setColor(0, 0, 255);
  myGLCD.drawRect(0, 14, 799, 465);
// Draw crosshairs
  myGLCD.drawLine(399, 15, 399, 464);
  myGLCD.drawLine(1, 239, 798, 239);
  for (int i=9; i<790; i+=10)
    myGLCD.drawLine(i, 237, i, 242);
  for (int i=19; i<470; i+=10)
    myGLCD.drawLine(397, i, 402, i);
// Draw sin-, cos- and tan-lines
  myGLCD.setColor(0,255,255);
  myGLCD.print("Sin", 5, 15);
  for (int i=1; i<798; i++)
    myGLCD.drawPixel(i,239+(sin(((i*1.13)*3.14)/180)*200));
  myGLCD.setColor(255,0,0);
  myGLCD.print("Cos", 5, 27);
    myGLCD.drawPixel(i,239+(cos(((i*1.13)*3.14)/180)*200));
  myGLCD.print("Tan", 5, 39);
    myGLCD.drawPixel(i,239+(tan(((i*0.9)*3.14)/180)));
  delay(2000);
  myGLCD.setColor(0,0,0);
  myGLCD.fillRect(1,15,798,464);
// Draw a moving sinewave
  x=1;
  for (int i=1; i<(798*20); i++)
    x++;
    if (x==799)
      x=1;
    if (i>799)
      if ((x==399)||(buf[x-1]==239))
        myGLCD.setColor(0,0,255);
      myGLCD.drawPixel(x,buf[x-1]);
    y=239+(sin(((i*1.65)*3.14)/180)*(200-(i / 100)));
    myGLCD.drawPixel(x,y);
    buf[x-1]=y;
  delay(2000);
// Draw some random filled rectangles
  for (int i=0; i<50; i++)
    myGLCD.setColor(random(255), random(255), random(255));
    x=2+random(746);
    y=16+random(397);
    x2=x+50;
    y2=y+50;
    myGLCD.fillRect(x, y, x2, y2);
  delay(2000);
// Draw some random filled, rounded rectangles
    x=2+random(746);
    y=16+random(397);
    x2=x+50;
    y2=y+50;
    myGLCD.fillRoundRect(x, y, x2, y2);
  delay(2000);
// Draw some random filled circles
    x=27+random(746);
    y=41+random(397);
    myGLCD.fillCircle(x, y, 25);
  delay(2000);
// Draw some lines in a pattern
  myGLCD.setColor (255,0,0);
  for (int i=15; i<463; i+=5)
    myGLCD.drawLine(1, i, (i*1.66)-10, 463);
  for (int i=463; i>15; i-=5)
    myGLCD.drawLine(798, i, (i*1.66)+30, 15);
  myGLCD.setColor (0,255,255);
    myGLCD.drawLine(1, i, 770-(i*1.66), 15);
    myGLCD.drawLine(798, i, 810-(i*1.66), 463);
  delay(2000);
// Draw some random circles
  for (int i=0; i<250; i++)
    x=32+random(736);
    y=45+random(386);
    r=random(30);
    myGLCD.drawCircle(x, y, r);
  delay(2000);
  delay (10000);
sorry for the double post, i had to remove the following code so it would fit within the max character limit of this forum. paste it all back in right above delay(10000); at the very bottom of the code.
// Draw some random rectangles
    x=2+random(796);
    y=16+random(447);
    x2=2+random(796);
    y2=16+random(447);
    myGLCD.drawRect(x, y, x2, y2);
  delay(2000);
// Draw some random rounded rectangles
    x=2+random(796);
    y=16+random(447);
    x2=2+random(796);
    y2=16+random(447);
    myGLCD.drawRoundRect(x, y, x2, y2);
  delay(2000);
    x=2+random(796);
    y=16+random(447);
    x2=2+random(796);
    y2=16+random(447);
    myGLCD.drawLine(x, y, x2, y2);
  delay(2000);
  for (int i=0; i<10000; i++)
    myGLCD.drawPixel(2+random(796), 16+random(447));
  delay(2000);
  myGLCD.fillScr(0, 0, 255);
  myGLCD.fillRoundRect(320, 190, 479, 289);
  myGLCD.print("That's it!", CENTER, 213);
  myGLCD.print("Restarting in a", CENTER, 239);
  myGLCD.print("few seconds...", CENTER, 252);
  myGLCD.setColor(0, 255, 0);
  myGLCD.setBackColor(0, 0, 255);
  myGLCD.print("Runtime: (msecs)", CENTER, 450);
  myGLCD.printNumI(millis(), CENTER, 465);
Edit: i can confirm that i am also using UTFT version 2.51. I assume you have the UTFT_CTE library? i am in the process of uploading the UFTF and UTFT_CTE libraries i have, and i will post a link shortly.
Edit 2: Dropbox - libraries.zip - Simplify your life
edit 3: you said you look through the forum and did not get anything to work, have you tired this thread? http://forum.arduino.cc/index.php?topic=152053.0
specifically, in one post someone
Note: There is a line " myGLCD.Swtich_LCD_TB_Bit(1); " which reverses the screen horizontally. Some of the example include it and some do not include it !! So, now that the UTFT demo works try the others BUT if any are backwards just add the above line straight after the first clear screen.
another person in that thread said it helped
Yes Im using Arduino Due!
I followed all your instructions for my own sample code… I only drew a rectangle, a circle, and a line of text.
In my code, I begin by clearing the screen, followed by this command:
myGLCD.Swtich_LCD_TB_Bit(0);
If I ommited it, then my text was mirrored horizontally.
Thank you for your help, the CTE UTFT libraries now work with my 7" SSD1963 display. Looking forward to trying the 5 " model.
I will be watching your work with the Henning’s library too.
thank you for your time.
i have found the problem to be an old version of UTFT.
i deleted all my old arduino folders and downloaded the new one but it would still not work. arduino had created a folder in my documents that actually stored the library's. deleting this folder and creating a fresh folder with the newest UTFT librarys fixed it up straight away.
thanks for the help. ewan
PROBLEMAS CON TOUCH SCREEN
Looking at this old thread I count help but notice something in the demo listing. About half way through it declares a char buf[33]; for one of the demos and immediately writes buf[33] = 0; which, of course, is one byte over the end of the array. This won't work in Mega.
