7-segement display fill direction
I'm using LED Control library for use with DCS BIOS for a flight simulator I'm building. I have gotten the display to work and properly display the desired data, however its filling from the opposite direction than what I want. For example '7---' '50--'. I would like for it start from the right and fill left as the digits increase. Ie. '---7' '--50'
Here is my code currently:
// Include DcsBios and LedControl libraries for 7-segment panel with Max7219 chip
#define DCSBIOS_IRQ_SERIAL
#include <LedControl.h>
#include <DcsBios.h>
/* Create function to configure a 7-segment panel. Pins DIN(12) CLK(11) CS(10) (1)panel */
LedControl lc = LedControl(12, 11, 10);
// IFEI Fuel Flow 7-Seg output
void onIfeiFfRChange(char* newValue) {
  /* your code here */
  lc.setChar(0, 3, 'F', false);
  lc.setChar(0, 0, newValue[2], false);
  lc.setChar(0, 1, newValue[1], false);
  lc.setChar(0, 2, newValue[0], false);
DcsBios::StringBuffer<3> ifeiFfRBuffer(0x7480, onIfeiFfRChange);
void onIfeiFfLChange(char* newValue) {
  lc.setChar(0, 5, newValue[2], false);
  lc.setChar(0, 6, newValue[1], false);
  lc.setChar(0, 7, newValue[0], false);
  lc.setChar(0, 4, 'F', false);
DcsBios::StringBuffer<3> ifeiFfLBuffer(0x747c, onIfeiFfLChange);
  DcsBios::setup();
  // MAX7219 INITIALISATION
  lc.shutdown(0, false);  //turn on the display
  lc.setIntensity(0, 8);  //set the brightness
  lc.clearDisplay(0);     //clear the display
  // custom boot code before connection
  lc.setChar(0, 7, '-', false);
  lc.setChar(0, 6, '-', false);
  lc.setChar(0, 5, '-', false);
  lc.setChar(0, 2, '-', false);
  lc.setChar(0, 1, '-', false);
  lc.setChar(0, 0, '-', false);
  DcsBios::loop();
Please read the forum guide in the sticky post at the top of any forum section. Your post above is breaking forum rules by not using code tags.
EDIT: thanks for fixing the code tags!
No problem, thanks for the tip
Try this and describe what happens
void reformat(char* newValue) {
  while(newValue[2] == ' ') {
    newValue[2] = newValue[1];
    newValue[1] = newValue[0];
    newValue[0] = ' ';
  reformat(newValue);
  reformat(newValue);
  DcsBios::setup();
  DcsBios::loop();
That did it! Thank you for your help
Enjoy your fish!
