not really a question but found this. code and it works so well ! had to search. for. a long time.
this code. displays numbers on your 7 segment display
int anodeLeds[] = {4, 5, 6, 7, 8, 9, 10};
int cathodeDigits[] = {1, 11, 12, 13};
int displayBuf[2];
int i = 0, j = 0;
int startTime = 0;
int endTime;
int num_array[10][7] = {
{ 1, 1, 1, 1, 1, 1, 0 }, // 0
{ 0, 1, 1, 0, 0, 0, 0 }, // 1
{ 1, 1, 0, 1, 1, 0, 1 }, // 2
{ 1, 1, 1, 1, 0, 0, 1 }, // 3
{ 0, 1, 1, 0, 0, 1, 1 }, // 4
{ 1, 0, 1, 1, 0, 1, 1 }, // 5
{ 1, 0, 1, 1, 1, 1, 1 }, // 6
{ 1, 1, 1, 0, 0, 0, 0 }, // 7
{ 1, 1, 1, 1, 1, 1, 1 }, // 8
{ 1, 1, 1, 0, 0, 1, 1 }
}; // 9
for (int i = 0; i < 7; i++)
pinMode(anodeLeds*, OUTPUT);*
- for (int i = 0; i < 4; i++)*
_ pinMode(cathodeDigits*, OUTPUT);_
_ }_
_ displayBuf[1] = 0; // initializes the display*_
* displayBuf[0] = 0;*
* // put your main code here, to run repeatedly:*
* refreshDisplay(displayBuf[1], displayBuf[0]);*
* // delay(1000);*
* endTime = millis(); // increments the counter approximately once a second*
* if ((endTime - startTime) >= 1000)*
* if (++i > 9)*
* i = 0;*
* if (++j > 9) j = 0;*
* displayBuf[0] = i; // send the updated count to the display buffer*
* displayBuf[1] = j;*
* startTime = endTime;*
void displayDigit(int digit)
* for (int i = 0; i < 7; i++)*
digitalWrite(anodeLeds, num_array[digit]);
void refreshDisplay(int digit1, int digit0)
* digitalWrite(cathodeDigits[0], HIGH); // displays digit 0 (least significant)*
* digitalWrite(cathodeDigits[1], LOW );*
* digitalWrite(cathodeDigits[2], HIGH );*
* digitalWrite(cathodeDigits[3], HIGH );*
* displayDigit(digit0);*
* delay(5);*
* digitalWrite(cathodeDigits[0], LOW); // then displays digit 1*
* digitalWrite(cathodeDigits[1], HIGH);*
* displayDigit(digit1);*
* delay(5);*
