Try this
const byte segA = 2;
const byte segB = 3;
const byte segC = 4;
const byte segD = 5;
const byte segE = A0; //pin 6 is used bij display 1 for its pwm function
const byte segF = 7;
const byte segG = 8;
//int segPD = ;
const byte digit_pin[] = {6, 9, 10, 11}; // PWM Display digit pins from left to right
const byte speakerPin = 15;
#define DIGIT_ON LOW
#define DIGIT_OFF HIGH
#define SEGMENT_ON HIGH
#define SEGMENT_OFF LOW
#define BRIGHTNESS 50
const byte button1 = 13;
const byte button2 = 12;
const byte button3 = 16;
const byte button4 = 17;
byte countdown_time = 60;
byte digit[4] = {0};
pinMode(segA, OUTPUT);
pinMode(segB, OUTPUT);
pinMode(segC, OUTPUT);
pinMode(segD, OUTPUT);
pinMode(segE, OUTPUT);
pinMode(segF, OUTPUT);
pinMode(segG, OUTPUT);
for (int i = 0; i < 4; i++) {
pinMode(digit_pin[i], OUTPUT);
pinMode(speakerPin, OUTPUT);
pinMode(button1, INPUT_PULLUP);
pinMode(button2, INPUT_PULLUP);
pinMode(button3, INPUT_PULLUP);
pinMode(button4, INPUT_PULLUP);
reset();
while (!Countdown(countdown_time, 962)) {
reset();
while (digitalRead(button2) == HIGH);
bool Countdown(int n, int del) {
for (int q = n; q > 0; q--) {
PrintNumber(q, del);
if (digitalRead(button2) == LOW)return false;
PrintNumber(0, 0);
playTone(1519, 1000);
return true;
void playTone(int tone, int duration) {
for (long k = 0; k < duration * 1000L; k += tone * 2) {
digitalWrite(speakerPin, HIGH);
delayMicroseconds(tone);
digitalWrite(speakerPin, LOW);
void SwitchDigit(byte dig) {
for (byte i = 0; i < 4; i++)
if (i == dig)analogWrite(digit_pin[i], BRIGHTNESS);
else digitalWrite(digit_pin[i], DIGIT_OFF);
void IntToDigits(int n) {
char i = 0;
if (n) {
while (i < 4) {
if (n > 0) {
digit[i] = n % 10;
n /= 10;
} else digit[i] = 10;
i++;
else {
digit[0] = 10;
digit[1] = 10;
digit[2] = 10;
digit[3] = 0;
void PrintNumber(int n, int time) {
IntToDigits(n);
for (int i = 0; i <= time / 20; i++) {
if (digitalRead(button2) == LOW) {
return;
for (byte j = 0; j < 4; j++) {
SwitchDigit(j);
lightNumber(digit[j]);
delay(5);
void reset() {
int pressed3 = 0, pressed4 = 0;
IntToDigits(countdown_time);
while (digitalRead(button1) == HIGH) {
for (int j = 0; j < 4; j++) {
SwitchDigit(j);
delay(5);
if (digitalRead(button3) == LOW) {
if (pressed3 == 0 || pressed3 > 30) {
if (countdown_time > 0) {
countdown_time -= 1 ;
pressed3 += 1;
else if (digitalRead(button4) == LOW) {
if (pressed4 == 0 || pressed4 > 30) {
if (countdown_time < 9999) {
countdown_time += 1 ;
pressed4 += 1;
if (digitalRead(button3) == HIGH)pressed3 = 0;
if (digitalRead(button4) == HIGH)pressed4 = 0;
void lightNumber(byte numberToDisplay) {
switch (numberToDisplay) {
case 0:
digitalWrite(segA, SEGMENT_ON);
digitalWrite(segB, SEGMENT_ON);
digitalWrite(segC, SEGMENT_ON);
digitalWrite(segD, SEGMENT_ON);
digitalWrite(segE, SEGMENT_ON);
digitalWrite(segF, SEGMENT_ON);
digitalWrite(segG, SEGMENT_OFF);
case 1:
digitalWrite(segA, SEGMENT_OFF);
digitalWrite(segD, SEGMENT_OFF);
digitalWrite(segE, SEGMENT_OFF);
digitalWrite(segF, SEGMENT_OFF);
case 2:
digitalWrite(segC, SEGMENT_OFF);
digitalWrite(segG, SEGMENT_ON);
case 3:
case 4:
case 5:
digitalWrite(segB, SEGMENT_OFF);
case 6:
case 7:
case 8:
case 9:
case 10:
