Hello, I am using a HDSP-5521 dual digit 7 segment display and i build a circuit with the Arduino Uno and Arduino WiFi shield. When i power it using the USB cable the brightness was perfect, however in my project i am required to power it with an external power supply, preferably using batteries and when i use a 9V battery or a DC power supply of 5V, the 7 segment became brighter and when it does the counting, i can still see it however the background of the 7 segment can be seen which makes it hard for the number to be seen correctly. Have anyone encountered this before? Thanks for anyone willing to help.
IF anyone is wondering if its a problem with the code, below is my code:
#include <SPI.h>
#include <WiFi.h>
// Arduino digital pins used to light up corresponding segments on the seven segment display
#define A 2
#define B 3
#define C 4
#define D 5
#define E 6
#define F_SEG 8
#define G 9
// Push button connected to pin 18 & Sensor connected to pin 17
#define PB 18
#define digitalDistanceSensor 17
// Pins driving common anodes
#define CA1 10
#define CA2 14
const int ledPin = 15;
const int speakerPin = 16;
char wifissid[] = "------"; // your network SSID (name)
char wifipass[] = "----";
int keyIndex = 0;
char devid[] = "---"; // Device ID for PushingBox scenario
char serverName[] = "api.pushingbox.com";
int count = 0;
boolean pinDevid1State = false; // To save last state of the pin for DEVID1
int status = WL_IDLE_STATUS; // Status of the Wifi
WiFiClient client;
char postmsg[100];
unsigned long timer1;
// Pins for A B C D E F G in sequence
const int segments[7] = {A, B, C, D, E, F_SEG, G};
// Segments that make each number
const byte numbers[10] = {0b1000000, 0b1111001, 0b0100100, 0b0110000, 0b0011001, 0b0010010, 0b0000010, 0b1111000, 0b0000000, 0b0010000}; //logic 0 to turn on segment (common anode)
pinMode(A, OUTPUT);
pinMode(B, OUTPUT);
pinMode(C, OUTPUT);
pinMode(D, OUTPUT);
pinMode(E, OUTPUT);
pinMode(F_SEG, OUTPUT);
pinMode(G, OUTPUT);
pinMode(PB, INPUT);
pinMode(digitalDistanceSensor, INPUT_PULLUP);
pinMode(CA1, OUTPUT);
pinMode(CA2, OUTPUT);
pinMode(speakerPin, OUTPUT);
pinMode(ledPin, OUTPUT);
Serial.println("Attempting to connect to WEP network...");
status = WiFi.begin(wifissid, keyIndex, wifipass);
if ( status != WL_CONNECTED) {
Serial.println("Couldn't get a wifi connection");
while (true);
else {
Serial.println("Connected to network");
timer1 = millis();
Serial.print("timer1:");
Serial.println(timer1);
int unitDigit = 0;
int tenthDigit = 0;
unsigned long interval = 60000; //60 seconds
unsigned long timer = timer1 + interval;
unsigned long currentMillis2 = currentMillis - timer1;
if ( currentMillis2 > timer && currentMillis2 < timer + 3000 )
unitDigit != (unitDigit + 1) % 10;
if (unitDigit == 0)
tenthDigit != (tenthDigit + 1) % 10;
sendingRequest();
else if (currentMillis2 > timer - 10000 && currentMillis2 < timer)
int currentState = digitalRead(digitalDistanceSensor); // read from sensor
digitalWrite(ledPin, HIGH);
if (currentState == LOW && pinDevid1State == false)
pinDevid1State = true;
if (currentState == HIGH && pinDevid1State == true)
count++;
Serial.println(currentMillis2);
Serial.print("Number of Counts : ");
Serial.print(count);
unitDigit = (unitDigit + 1) % 10;
if (unitDigit == 0) {
tenthDigit = (tenthDigit + 1) % 10;
else if (currentMillis2 < timer - 10000)
count++;
// display number
unsigned long startTime = millis();
for (unsigned long elapsed = 0; elapsed < 600; elapsed = millis() - startTime)
tenthsDigit(numbers[tenthDigit]);
delay(5);
unitsDigit(numbers[unitDigit]);
delay(5);
// reset count
int button = digitalRead(PB);
if (button == LOW)
//unitDigit = 0;
//tenthDigit = 0;
void unitsDigit(byte number)
digitalWrite(CA1, LOW); // set the LED off
digitalWrite(CA2, HIGH); // set the LED on
lightSegments(number);
void tenthsDigit(byte number)
digitalWrite(CA1, HIGH); // set the LED on
digitalWrite(CA2, LOW); // set the LED off
void lightSegments(byte number)
for (int i = 0; i < 7; i++)
int bit = bitRead(number, i);
digitalWrite(segments[i], bit);
void sendingRequest()
digitalWrite(ledPin, LOW);
digitalWrite(speakerPin, HIGH);
digitalWrite(speakerPin, LOW);
if (client.connect(serverName, 80)) {
Serial.println("connected");
Serial.println("sending request");
sprintf(postmsg, "GET /pushingbox?devid=-----&count=%d HTTP/1.1", count);
client.println(postmsg);
client.print("Host: ");
client.println(serverName);
client.println("User-Agent: Arduino");;
client.println();
Serial.println(postmsg);
Serial.println("Host: api.pushingbox.com");
Serial.println("Connection: close");
count = 0;
else {
Serial.println("Connection Failed");
client.stop();
count = 0;
