I'm new to Arduino and have been playing around with it for a couple of weeks. I'm currently working on a shuffleboard score keeper that counts from 0 to 21 using RF transmitter and receiver. I have one Arduino transmitting data using two push buttons(player1 and player2). I have another Arduino receiving the data and displaying it on 2 dual 7-segment displays.
Problem: I'm having problems updating the 2 dual 7-segment displays on the receiver. If I put a delay in certain places it will update the displays, but cause one of the dual display segments to fade . If I don't put delays it will never update the counter.
Some of the hardware I'm using:
- 433Mhz RF transmitter and receiver to transfer the data
- 2 digit seven segment common cathode displays (two of these one for player1 and player2 .
- 4 74HC595 8 bit Shift Register
- 2 Arduino Uno
Here's my code without any of the delays.
#include <VirtualWire.h>
//set arduino pins for 2 shift registers
const int dataPlayer1=6;
const int clockPlayer1=7;
const int latchPlayer1=5;
const int dataPlayer2=9;
const int clockPlayer2=10;
const int latchPlayer2=8;
//GroundConnectionsForSegments
int shiftRegisterGroundConnectionToSegmentDigitOne=B00100000;
int shiftRegisterGroundConnectionToSegmentDigitTwo=B01000000;
//setting segments to represent numbers
int zero =B11101101; //0
int one =B01000001; //1
int two =B01111100; //2
int three =B01111001; //3
int four =B11010001; //4
int five =B10111001; //5
int six =B10111101; //6
int seven =B01100001; //7
int eight =B11111101; //8
int nine =B11110001; //9
int numReceivedRFPlayer1=0;
int numReceivedRFPlayer2=0;
int segmentOneNumberRepresentationPlayer1;
int segmentTwoNumberRepresentationPlayer1;
int segmentOneNumberRepresentationPlayer2;
int segmentTwoNumberRepresentationPlayer2;
pinMode(dataPlayer1,OUTPUT);
pinMode(clockPlayer1,OUTPUT);
pinMode(latchPlayer1,OUTPUT);
pinMode(dataPlayer2,OUTPUT);
pinMode(clockPlayer2,OUTPUT);
pinMode(latchPlayer2,OUTPUT);
//receiver
//Initialise the IO and ISR
vw_set_rx_pin(12); // We will be receiving on pin 4 i.e the RX pin from the module connects to this pin.
vw_setup(2000); // Bits per sec
vw_rx_start();
ReceiverRF();
Player1();
Player2();
void ReceiverRF()
int num;
uint8_t buf[VW_MAX_MESSAGE_LEN];
uint8_t buflen = VW_MAX_MESSAGE_LEN;
//see if we have received a message from our transmitter
if (vw_get_message(buf, &buflen))
//example of data coming in F1, F2....F10 - S1, S2....S10
char val[buflen]; //Same as buf, last char will be used for null terminator
memset(val, '\0', sizeof(val));
//Copy value from string
strncpy(val, (char *)buf + 1, buflen - 1);
//convert string containing value to integer
int VAL = atoi( val );
switch (buf[0]) {
case 'F':
//NumberReceived from transmitter for player 1
numReceivedRFPlayer1=VAL;
case 'S':
//NumberReceived from transmitter for player 2
numReceivedRFPlayer2=VAL;
default: //do nothing
void Player1()
//Get 7 segment representation for number transmitted for player 1
segmentOneNumberRepresentationPlayer1 = getNumberRepresentationForSegmentOne(numReceivedRFPlayer1);
segmentTwoNumberRepresentationPlayer1 = getNumberRepresentationForSegmentTwo(numReceivedRFPlayer1);
//Set the 7 segment display
setNumberForSegmentOne(segmentOneNumberRepresentationPlayer1, dataPlayer1, clockPlayer1, latchPlayer1);
setNumberForSegmentTwo(segmentTwoNumberRepresentationPlayer1, dataPlayer1, clockPlayer1, latchPlayer1);
void Player2()
//Get 7 segment representation for number transmitted for player 2
segmentOneNumberRepresentationPlayer2 = getNumberRepresentationForSegmentOne(numReceivedRFPlayer2);
segmentTwoNumberRepresentationPlayer2 = getNumberRepresentationForSegmentTwo(numReceivedRFPlayer2);
setNumberForSegmentOne(segmentOneNumberRepresentationPlayer2, dataPlayer2, clockPlayer2, latchPlayer2);
setNumberForSegmentTwo(segmentTwoNumberRepresentationPlayer2, dataPlayer2, clockPlayer2, latchPlayer2);
int getNumberRepresentationForSegmentOne(int number)
int segmentOne = zero;
//set segment one to 1
if (number >= 10 && number <= 19)
segmentOne = one;
//set segment one to 2
if (number >= 20 && number <= 21)
segmentOne = two;
return segmentOne;
//This is ugly I will stream line this. Better way to write this code
int getNumberRepresentationForSegmentTwo(int number)
int segmentTwo = zero;
switch (number) {
case 0:
segmentTwo=zero;
case 1:
segmentTwo=one;
case 2:
segmentTwo=two;
case 3:
segmentTwo=three;
case 4:
segmentTwo=four;
case 5:
segmentTwo=five;
case 6:
segmentTwo=six;
case 7:
segmentTwo=seven;
case 8:
segmentTwo=eight;
case 9:
segmentTwo=nine;
case 10:
segmentTwo=zero;
case 11:
segmentTwo=one;
case 12:
segmentTwo=two;
case 13:
segmentTwo=three;
case 14:
segmentTwo=four;
case 15:
segmentTwo=five;
case 16:
segmentTwo=six;
case 17:
segmentTwo=seven;
case 18:
segmentTwo=eight;
case 19:
segmentTwo=nine;
case 20:
segmentTwo=zero;
case 21:
segmentTwo=one;
return segmentTwo;
void setNumberForSegmentOne(int segmentOne, int data, int clock, int latch)
digitalWrite(latch,LOW);
shiftOut(data,clock,LSBFIRST,shiftRegisterGroundConnectionToSegmentDigitOne);
shiftOut(data,clock,LSBFIRST,segmentOne);
digitalWrite(latch,HIGH);
void setNumberForSegmentTwo(int segmentTwo, int data, int clock, int latch)
shiftOut(data,clock,LSBFIRST,shiftRegisterGroundConnectionToSegmentDigitTwo);
shiftOut(data,clock,LSBFIRST,segmentTwo);
