Hello there!
I'm fairly new to the more "software" side of Arduino (I've built several robots with it LMR FTW) and I'm trying to make a 7 segment display (1 digit) show the time. I'd like it to show the first digit of the hour, second digit of the hour, first digit of the minute, and the second digit of the minute when I press a button (on pin 1). The pins for the 7 segment are as follows: 2,3,4,5,6,7,8, and 9. I basically mashed two example codes, got rid of the icky stuff, and made myself a sort of core. Ultimately, I'd like to transpose this onto my ATtiny 44A and make a wrist watch out of it (After some pin changes). The code can already keep time, send it to the serial port, and receive time changes using UNIX time stamps. It already has the codes set up for displaying numbers 1 through 9 on the seven segment. It has all been tested up to there. So, do you think you can help me finish the code? Fabulous! Thanks a bunch!
#include <Time.h>
#define TIME_MSG_LEN 11 // time sync to PC is HEADER followed by Unix time_t as ten ASCII digits
#define TIME_HEADER 'T' // Header tag for serial time sync message
#define TIME_REQUEST 7 // ASCII bell character requests a time sync message
// T1262347200 //noon Jan 1 2010
const int buttonPin = 2;
int buttonState = 0;
byte seven_seg_digits[10][7] = { { 1,1,1,1,1,1,0 }, // = 0
{ 0,1,1,0,0,0,0 }, // = 1
{ 1,1,0,1,1,0,1 }, // = 2
{ 1,1,1,1,0,0,1 }, // = 3
{ 0,1,1,0,0,1,1 }, // = 4
{ 1,0,1,1,0,1,1 }, // = 5
{ 1,0,1,1,1,1,1 }, // = 6
{ 1,1,1,0,0,0,0 }, // = 7
{ 1,1,1,1,1,1,1 }, // = 8
{ 1,1,1,0,0,1,1 } // = 9
pinMode(buttonPin, INPUT);
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(7, OUTPUT);
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
writeDot(0); // start with the "dot" off
void writeDot(byte dot) {
digitalWrite(9, dot);
void sevenSegWrite(byte digit) {
byte pin = 2;
for (byte segCount = 0; segCount < 7; ++segCount) {
digitalWrite(pin, seven_seg_digits[digit][segCount]);
++pin;
void loop(){
if(Serial.available() )
processSyncMessage();
if(timeStatus() == timeNotSet)
Serial.println("waiting for sync message");
digitalClockDisplay();
void digitalClockDisplay(){
// digital clock display of the time
Serial.print(hour());
printDigits(minute());
printDigits(second());
Serial.print(" ");
Serial.print(day());
Serial.print(" ");
Serial.print(month());
Serial.print(" ");
Serial.print(year());
void printDigits(int digits){
// utility function for digital clock display: prints preceding colon and leading 0
Serial.print(":");
if(digits < 10)
Serial.print('0');
Serial.print(digits);
void processSyncMessage() {
// if time sync available from serial port, update time and return true
while(Serial.available() >= TIME_MSG_LEN ){ // time message consists of header & 10 ASCII digits
char c = Serial.read() ;
Serial.print(c);
if( c == TIME_HEADER ) {
time_t pctime = 0;
for(int i=0; i < TIME_MSG_LEN -1; i++){
c = Serial.read();
if( c >= '0' && c <= '9'){
pctime = (10 * pctime) + (c - '0') ; // convert digits to a number
setTime(pctime); // Sync Arduino clock to the time received on the serial port
void leddisplay(){
//addition to BOTH of the codes; a sort of marriage between them.
buttonState = digitalRead(buttonPin);
if (buttonState == HIGH) {
//here the time would convert to the 7 segment display
If you have read all the way to here, you're the best <3 :*
