7 Segment display
I have a question here. Is it possible to program both increment and decrease value on 7 segment display because i only be able to program the 7 segment display to increase value. Logic is my project have 3 push button switch, 1 push button is for increase value second is for decrease value and last one is for reset the value to zero. Im newbie in programming and my lecturer ask me to learn this by myself. sorry for the bad english because english is not my mother tongue.
Yes.
So should you be asking here?
We need to see your code and a schematic (not a Fritzing physical layout diagram) showing how you have wired things up. Please read this before posting code:- How to use this forum
Grumpy_Mike:
Yes.
My lecturer said that we can ask around the web. So i did it.
this is the coding :
byte numbers[10] = {
                    B11111100, B01100000, B11011010, B11110010, B01100110,
                    B10110110, B10111110, B11100000, B11111110, B11100110
    for(int i = 2; i <= 8; i++) {
        pinMode(i, OUTPUT);
    pinMode(9, INPUT);
int counter = 9;
bool go_by_switch = true;
int last_input_value = LOW;
    if(go_by_switch) {
        int switch_input_value = digitalRead(9);
        if(last_input_value == LOW && switch_input_value == HIGH) {
            counter = (counter + 1) % 10;
        last_input_value = switch_input_value;
    writeNumber(counter);
void writeNumber(int number) {
    if(number < 0 || number > 9) {
        return;
    byte mask = numbers[number];
    byte currentPinMask = B10000000;
        if(mask & currentPinMask) digitalWrite(i,HIGH);
        else digitalWrite(i,LOW);
    currentPinMask = currentPinMask >> 1;
You need a resistor in each anode not one in the common cathode. As you have it the brightness will change depending on the number of segments that are lit.
There is only one button in that diagram.
What is that code doing that you don't want it to?
[/quote]
Grumpy_Mike: You need a resistor in each anode not one in the common cathode. As you have it the brightness will change depending on the number of segments that are lit. There is only one button in that diagram.
Dear mike,
I already put the resistor in each anode. The problem is, I do not know how to modify the circuit for it to have 3 input switch. I already done the reset button thing last night. I only be able to modify the coding to increase or decrease value one at a time.
I need to modify the coding to have both increase and decrease value. The code i give to u in last post was working perfectly. I just dont get it how to modify the coding.
First you need to modify the diagram and add another button.
Then you need to test for that button like you did for the one you have. When you see it being pressed you call a new function that is almost identical to the one you have only this time decrement the number.
Grumpy_Mike:
Dear Mike, i already done add one input for switch and already tested and it works. But now whenever i press my switches, the number change randomly. Below are my coding and i hope you can correct me.
        pinMode(i, OUTPUT);
    pinMode(10, INPUT);
    pinMode(13, INPUT);
int counter = 9;
    if(go_by_switch) {
        int switch_input_value = digitalRead(13);
    if(go_by_switch) {
        int switch_input_value = digitalRead(10);
            counter = (counter - 1) % 10;
        return;
You are using the same variable for the last value for both switches. These need to be a separate variable for each switch.
Grumpy_Mike: You are using the same variable for the last value for both switches. These need to be a separate variable for each switch.
Dear Mike,
I do not know how to separate the variable. Already try google about debounce but i still do not understand how the coding works. Sorry for being so dumb at coding.
I did not say separate the variables, I said use separate variables.
So instead of using last_input_value for both buttons you use last_input_value_up for the up button and last_input_value_down for the down button.
You do not need any debounce with your delay( 500 ), in fact that could be delay( 50 )
Grumpy_Mike:
Thank you so much random guy. I have succeed by your help. My the god bless your soul. Thanks again for being such a big help. You’re my hero. And below is my new code. Thanks again sir.
        pinMode(i, OUTPUT);
    pinMode(10, INPUT);
    pinMode(13, INPUT);
int counter = 9;
int last_input_up = LOW;
int last_input_down = LOW;
    if(go_by_switch) {
        if(last_input_up == LOW && switch_input_value == HIGH) {
        last_input_up = switch_input_value;
    if(go_by_switch) {
        if(last_input_down == LOW && switch_input_value == HIGH) {
        last_input_down = switch_input_value;
        return;
Hey that's fine, glad you got it going. You show the right attitude to learning stuff, well done.
