7 Segment LED code help
Im using the following code to test run the LED but output 1 segment (A) never turns off?
Thanks
int a=1, b=2, c=3, d=4, e=5, f=6, g=7, dp=8;
int pins[8] = {a,b,c,d,e,f,g,dp};
for (int i = 0; i < 8; i++) {
pinMode(pins*, OUTPUT);*
_ digitalWrite(pins*, HIGH);_
_
delay(250);_
_
}*_
_ digitalWrite(pins*, LOW);
delay(50);
}*_
Because pin 1 is used by the serial communications along with pin 0 so don't use it.
Ok thanks
