7 segment LED Help
Hi, so I was making one morse code translator that uses serial monitor, But I want to add a 7 segment display to it so it shows the letter, this is the first time I am in touch with 7 segment display, so could somebody please help me or give me advice? I did some research, but I still have no idea how can I import it into the translator.
Here is what I have currently
#define buttonPin  2
#define ledPin 13
#define lledPin 12
#define buzzer 9
#define pot A0
bool buttonState, lastButtonState, cheker = false, linecheker = false, longclick = true;
int pause_value, signal_length = 0, pause = 0;
String morse;
char dash = '-', dot = '*';
void setup(){
  pinMode(buttonPin, INPUT_PULLUP);
  pinMode(ledPin, OUTPUT);
  pinMode(buzzer, OUTPUT);
  digitalWrite(ledPin, HIGH);
  tone(buzzer, 1397);
  delay(200);
  digitalWrite(ledPin, LOW);
  noTone(buzzer);
  pause_value = map(analogRead(pot), 0, 1023, 70, 300);
  buttonState = !digitalRead(buttonPin);
  if(Serial.available() > 0) longclick = (Serial.read() == 't') ? true : false;
  if (buttonState && lastButtonState){
    signal_length++;
    if (signal_length < 2*pause_value){
    tone(buzzer, 1397);
    else if(longclick){
      tone(buzzer, 1397);
      analogWrite(lledPin, HIGH);
  else if(!buttonState && lastButtonState){
     if (signal_length > 50 && signal_length < 2*pause_value ) morse += dot;
      else if (signal_length > 2*pause_value) morse += dash;
    signal_length = 0;
    noTone(buzzer);
  else if(buttonState && !lastButtonState){
    pause = 0;
    cheker = true;
    linecheker = true;
  else if (!buttonState && !lastButtonState){
    pause++;
    if (pause > 3*pause_value && cheker){
      translate();
      cheker = false;
      morse = "";
    if ((pause > 15*pause_value) && linecheker){
      linecheker = false;
  lastButtonState = buttonState;
  delay(1);
void translate(){
  if (morse=="*-")
    Serial.print("A");
  else if (morse=="-***")
    Serial.print("B");
  else if (morse=="-*-*")
    Serial.print("C");
  else if (morse=="-**")
    Serial.print("D");
  else if (morse=="*")
    Serial.print("E");
  else if (morse=="**-*")
    Serial.print("F");
  else if (morse=="--*")
    Serial.print("G");
  else if (morse=="****")
    Serial.print("H");
  else if (morse=="**")
    Serial.print("I");
  else if (morse=="*---")
    Serial.print("J");
  else if (morse=="-*-")
    Serial.print("K");
  else if (morse=="*-**")
    Serial.print("L");
  else if (morse=="--")
    Serial.print("M");
  else if (morse=="-*")
    Serial.print("N");
  else if (morse=="---")
    Serial.print("O");
  else if (morse=="*--*")
    Serial.print("P");
  else if (morse=="--*-")
    Serial.print("Q");
  else if (morse=="*-*")
    Serial.print("R");
  else if (morse=="***")
    Serial.print("S");
  else if (morse=="-")
    Serial.print("T");
  else if (morse=="**-")
    Serial.print("U");
  else if (morse=="***-")
    Serial.print("V");
  else if (morse=="*--")
    Serial.print("W");
  else if (morse=="-**-")
    Serial.print("X");
  else if (morse=="-*--")
    Serial.print("Y");
  else if (morse=="--**")
    Serial.print("Z");
  else if (morse=="*----")
    Serial.print("1");
  else if (morse=="**---")
    Serial.print("2");
  else if (morse=="***--")
    Serial.print("3");
  else if (morse=="****-")
    Serial.print("4");
  else if (morse=="*****")
    Serial.print("5");
  else if (morse=="-****")
    Serial.print("6");
  else if (morse=="--***")
    Serial.print("7");
  else if (morse=="---**")
    Serial.print("8");
  else if (morse=="----*")
    Serial.print("9");
  else if (morse=="-----")
    Serial.print("0");
A seven segment display is good at numerals. Letters, not so much. Most of the letters you can represent on a 7-segment are distortions of the standard look - and few are upper case. For instance, what to do about '6', 'G', and'b'? For some of them a good imagination is required to see the desired character.
If you want a truer representation a 14-segment or 8x8 matrix display might be a better choice.
For the translation you may find something useful by forum searches with 'Morse code' in the search box.
YMMV
