Hello, I want your help to do this please (I've multiplexed 3 LED's):
One of the two buttons allow you to select the module you want to display (only displayed 1 simultaneously), ie, each press will advance to the next module, considering that there are 3 modules are numbered from 1 to 3. The other button, when clicked, will increase by 1 the value of the selected display to the previous button. The program should remember that value had each of the displays.
-All displays start in first round '0' and when the first round is over, each display will remember their value, starting with that value. For example:
First round [ 0,0,0] We put: [2,5,8] So: Second round will start [2,5,8]
I tried putting how to turn on each display with button 2 (P2) but I couldn't check it, I would fail to do that and to remember the value, I have been told that it works with a vector
int num = 0;
int delayTime;
int counter=1;
int estadoBoton1 = 0;
int estadoBoton2 = 0;
int P1 = 3;
int P2 = 2;
//Displays multiplexed
int LED1=4;
int LED2=5;
int LED3=6;
void setup (){
pinMode(P2, INPUT);
pinMode(P1, INPUT);
pinMode(7, OUTPUT);
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
pinMode(10, OUTPUT);
pinMode(11, OUTPUT);
pinMode(12, OUTPUT);
pinMode(13, OUTPUT);
//Display Multiplexed
pinMode(LED1, OUTPUT);
pinMode(LED2, OUTPUT);
pinMode(LED3, OUTPUT);
void loop(){
estadoBoton1 = digitalRead(P1);
estadoBoton2 = digitalRead(P2);
Serial.println(estadoBoton1);
delay(50);
Serial.println(estadoBoton2);
delay(50);
if (estadoBoton1 == HIGH) {
num = num+ 1;
if (num >= 10){
num=0;
if (estadoBoton2 == HIGH) {
counter + 1;
//reset counter
if(counter == 4) {
counter = 1;
//Change mode
if(counter == 1)
delayTime = 250;
else if(counter == 2)
delayTime = 100;
else if(counter == 3)
delayTime = 50;
//Light show!
digitalWrite(LED4, HIGH);
delay(delayTime);
digitalWrite(LED4, LOW);
digitalWrite(LED5, HIGH);
delay(delayTime);
digitalWrite(LED5, LOW);
digitalWrite(LED6, HIGH);
delay(delayTime);
digitalWrite(LED6, LOW);
delay(delayTime);
switch (num) {
case 0:
limpiar();
cero();
case 1:
limpiar();
uno();
case 2:
limpiar();
dos();
case 3:
limpiar();
tres();
case 4:
limpiar();
cuatro();
case 5:
limpiar();
cinco();
case 6:
limpiar();
seis();
case 7:
limpiar();
siete();
case 8:
limpiar();
ocho();
case 9:
limpiar();
nueve();
void cero(){
digitalWrite(7,HIGH);
digitalWrite(8,HIGH);
digitalWrite(9,HIGH);
digitalWrite(10,HIGH);
digitalWrite(11,HIGH);
digitalWrite(12,HIGH);
void uno(){
void dos(){
digitalWrite(13,HIGH);
void tres(){
void cuatro(){
void cinco(){
void seis(){
void siete(){
void ocho(){
void nueve(){
void limpiar(){
digitalWrite(7,LOW);
digitalWrite(8,LOW);
digitalWrite(9,LOW);
digitalWrite(10,LOW);
digitalWrite(11,LOW);
digitalWrite(12,LOW);
digitalWrite(13,LOW);
Please guide me through this... I know that you guys are all good at it...
