7-segment -shift register
I'm building a display using an Arduino uno,2 x 3 digit 7 Segment common anode, and tow 74HC595 shift registers.
my problem is blinking (display.show(1000)) every 1 second
I use it to show temperature,I use <ShiftDisplay.h>library with my program
can any one help me
Please post your code
#include <ShiftDisplay.h>
const int LATCH_PIN = 6;
const int CLOCK_PIN = 7;
const int DATA_PIN = 5;
const DisplayType DISPLAY_TYPE = COMMON_ANODE; // COMMON_CATHODE or COMMON_ANODE
const int DISPLAY_SIZE = 6; // number of digits on display
ShiftDisplay display(LATCH_PIN, CLOCK_PIN, DATA_PIN, DISPLAY_TYPE, DISPLAY_SIZE);
int Vo;
float R1 = 10000;
float logR2, R2, Rt,Ft, T, Eva_t;
float c1 = 1.009249522e-03, c2 = 2.378405444e-04, c3 = 2.019202697e-07;
void setup(){
display_set()
} void desplay_set() {
int Ft1,Rt1;
const unsigned int tot_time=D_time+DF_duration;
get_ref_temp();get_fre_temp();
String condition1 ;
if(Ft>9){condition1="0"+String(int(Ft));}
else if(Ft>0){
condition1=" 0"+String(int(Ft));}
else if(Ft==0){
condition1=" 00";}
else if(Ft>-9){
condition1="-0"+String(int(abs(Ft)));}
else{condition1=String(int(Ft));}
String condition2;
if(Rt>9){condition2="0"+String(int(Rt));}
else if(Rt>0){condition2=" 0"+String(int(Rt));}
else if(Rt==0){condition2=" 00";}
else if(Rt>-9){ condition2="-0"+String(int(abs(Rt)));}
else{condition2=String(int(Rt));}
display.set(condition1+condition2,ALIGN_LEFT);
display.show(1000);
return;
void get_fre_temp() {
float f_tempavg=0;
for (int i = 0; i < 50; i++) {
Vo = analogRead(fre_Pin); R2 = R1 * (1023.0 / Vo-1.0); logR2 = log(R2);
T = (1.0 / (c1 + c2 * logR2 + c3 * logR2 * logR2 * logR2));
Ft = T - 273.15; f_tempavg+= Ft;}
Ft = int(f_tempavg /50);
return;
//--------------get refregerator temperature-------------------------
void get_ref_temp() {
float r_tempavg=0;
Vo = analogRead(ref_pin); R2 = R1 * (1023.0 / Vo-1.0); logR2 = log(R2);
Rt = T - 273.15; r_tempavg+= Rt;}
Rt = int(r_tempavg /50);
return;
  display_set()
Have you got a program that compiles ?
no that's not all the sketch
the program works good compiled and uploaded successfully
put the blink of the display every 1 sec or 5 sec as the code display.show(1000) or display.show(5000)
Now you are issuing orders rather than asking for help
display.show(1000);
display.show(5000);
Are they functions in the library or did you invent them ?
Where did you get the ShiftDisplay library from ?
