7 segment timer 2 numbers
I found this code which seems to work. it is a sort timer being displayed on the 7 segment display.
but my Arduino crashes after some time.
here is my code
int anodeLeds[] = {4, 5, 6, 7, 8, 9, 10};
int cathodeDigits[] = {1, 11, 12, 13};
int displayBuf[2];
int i = 0, j = 0;
int startTime = 0;
int endTime;
int num_array[10][7] = {
{ 1, 1, 1, 1, 1, 1, 0 }, // 0
{ 0, 1, 1, 0, 0, 0, 0 }, // 1
{ 1, 1, 0, 1, 1, 0, 1 }, // 2
{ 1, 1, 1, 1, 0, 0, 1 }, // 3
{ 0, 1, 1, 0, 0, 1, 1 }, // 4
{ 1, 0, 1, 1, 0, 1, 1 }, // 5
{ 1, 0, 1, 1, 1, 1, 1 }, // 6
{ 1, 1, 1, 0, 0, 0, 0 }, // 7
{ 1, 1, 1, 1, 1, 1, 1 }, // 8
{ 1, 1, 1, 0, 0, 1, 1 }
}; // 9
for (int i = 0; i < 7; i++)
pinMode(anodeLeds*, OUTPUT);*
  • for (int i = 0; i < 4; i++)*
    _ pinMode(cathodeDigits*, OUTPUT);_
    _
    }_
    _
    displayBuf[1] = 0; // initializes the display*_
    * displayBuf[0] = 0;*
    * Serial.begin(9600);*
    * // put your main code here, to run repeatedly:*
    * refreshDisplay(displayBuf[1], displayBuf[0]);*
    * // delay(1000);*
    * endTime = millis(); // increments the counter approximately once a second*
    * if ((endTime - startTime) >= 1000)*
    * if (++i > 9)*
    * i = 0;*
    * if (++j > 9) j = 0;*
    * displayBuf[0] = i; // send the updated count to the display buffer*
    * displayBuf[1] = j;*
    * startTime = endTime;*
    void displayDigit(int digit)
    * for (int i = 0; i < 7; i++)*
    digitalWrite(anodeLeds, num_array[digit]);
    void refreshDisplay(int digit1, int digit0)
    * digitalWrite(cathodeDigits[0], HIGH); // displays digit 0 (least significant)*
    * digitalWrite(cathodeDigits[1], HIGH );*
    * digitalWrite(cathodeDigits[2], LOW );*
    * digitalWrite(cathodeDigits[3], HIGH );*
    * displayDigit(digit0);*
    * delay(5);*
    * digitalWrite(cathodeDigits[0], HIGH); // then displays digit 1*
    * digitalWrite(cathodeDigits[1], LOW);*
    * digitalWrite(cathodeDigits[2], HIGH );*
    * displayDigit(digit1);*
    * delay(5);*
Your time variables need to be unsigned long, not int
