I'm using a 74HC165E to shift 8 pushbuttons into the Arduino using 3 wires.
Switch 1 is connected to IC Pin 11 (D0)
Switch 8 is connected to IC Pin 6 (D7)
(cf. pin layout from datasheet)
Using the following sketch code:
int latchPin = 5;
int dataPin = 6;
int clockPin = 7;
int input;
pinMode(5, OUTPUT);
pinMode(6, INPUT);
pinMode(7, OUTPUT);
digitalWrite(latchPin, HIGH);
input = shiftIn(dataPin, clockPin, MSBFIRST);
digitalWrite(latchPin, LOW);
Serial.println(input);
I get the following results:
No press -> 255
Switch 1 -> 253 (i.e bit 2 — binary 2)
Switch 2 -> 251 (i.e bit 3 — binary 4)
Switch 3 -> 247 (i.e bit 4 — binary 8)
Switch 7 -> 127 (i.e bit 8 — binary 128)
BUT
Switch 8 -> 254 (i.e bit 1 — binary 1)
which seems odd because all the buttons are switched sequentially. If the wires were not properly connected, I'd get no behavior at all. But here, all the switches are working, only with the bits shifted around one position to the left (or right, because with LSBFIRST I get the opposite behavior, i.e. the bits shifted from the buttons are in this order: 64, 32, 16, 8, 4, 2, 1, 128).
Is there a problem somewhere, or is it normal for the IC input pin switches to work in this order: D7, D0, D1, D2, D3, D4, D5, D6?
Thanks.
BTW it's easier to see with "Serial.println(255^input);" but the result is the same, obviously.
