Hello people,
I'm making a library in order to control one or more shift registers.
Here is the code:
ShiftRegister.h
ShiftRegister.h - Library for using a shift register.
#ifndef ShiftRegister_h
#define ShiftRegister_h
#include "Arduino.h"
class ShiftRegister
public:
ShiftRegister(int clockPin, int latchPin, int dataPin);
shiftDataOut(byte *data);
private:
byte getPage();
int _latchPin;
int _clockPin;
int _dataPin;
#endif
ShiftRegister.cpp
#include "ShiftRegister.h"
ShiftRegister::ShiftRegister(int clockPin, int latchPin, int dataPin)
_latchPin = latchPin;
_clockPin = clockPin;
_dataPin = dataPin;
pinMode(_latchPin, OUTPUT);
pinMode(_clockPin, OUTPUT);
pinMode(_dataPin, INPUT);
ShiftRegister::shiftDataOut(byte *data)
// set latchPin LOW so the register loads data from its inputs
digitalWrite(_latchPin, 0);
// wait a little
//delay(2000);
//set it to HIGH to collect parallel data
digitalWrite(_latchPin, 1);
for (int i = 0; i < sizeof(data); i++)
data[i] = ShiftRegister::getPage();
byte ShiftRegister::getPage() {
byte pageData = 0;
Serial.println("---");
for (int i = 7; i >= 0; i--)
// set clock pin to LOW in order to shift a bit
digitalWrite(_clockPin, 0);
delay(100);
Serial.print(digitalRead(_dataPin));
if (digitalRead(_dataPin)) {
pageData = pageData | (1 << i);
// the job is done, so set it to HIGH
digitalWrite(_clockPin, 1);
Serial.println("");
return pageData;
Main.ino
#include "ShiftRegister.h";
//ShiftRegister::ShiftRegister(int clockPin, int latchPin, int dataPin)
ShiftRegister regist(10, 8, 11);
byte data;
regist.shiftDataOut(&data);
Serial.print("data: ");
Serial.println(data, BIN);
delay(400);
I'm facing this problem:
I cannot pass an array to shiftDataOut method to hold the data. Right now I can only pass a byte, but I would like to be able to pass an array of bytes in order to store into them the values read by the registers. Is this possible?
Thank you!
