74HC595 - led won't light up
i played around with the 74HC595 today and followed the playground tutorial regarding this piece of hardware.
The problem is that non of my leds are willing wo light up. I tripple checked the wireup and im sure this is not the problem.
I can measure voltage on the output pins of the 74HC595. Here is a foto of the setup:
After hours of searching i loaded up the blink sketch ( pin13 high/low ) and wired up an led with a 220ohm resistor to it.
The funny thing now is that even that LED is not willing to light up. I check that the anode is in the right direction.
So i tried something even more basic:
I wired the resistor and the led to the 5V output of the arduino and wired the cathode to a ground pin.
Nothing happend :frowning: Could it be that i somehow fried my arduino ?
What should be my next steps ?
Thank you :slight_smile:
So after playing around i finally got a single led to blink :slight_smile:
The thing to remember was that a row on a breadboard is connected. So when i inserted a LED with anode + cathode into the same row i basicly shortcuted the way fpr the current - avoiding my led :confused:
Sorry, im dumb :slight_smile:
*close please
im dumb
This serves no useful purpose.
You learn from your mistakes, like all of us.
You won't make the same mistake, until you get older :wink:
