74hc595 non scrolling problem
i want to display a dynamic clock using rtc1302 like 7 segment display using 48 x 6 leds 74hc595 ic + 2npn222
but i am stuck at some places
thanks in advance
code.txt (27.5 KB)
rahulbaruri:
I can't think of anyone that is going to take the time to wire up (7)74hc595, (8)2npn222, 48x6 LEDs and (56) resisitors just to figure out where you are stuck. You're going to need to give more details.
OP's Circuit
OP's code (part 1) (minus the huge areas of commented code)
#define max_char 100
int charIndex;
int scrollspeed = 3; //Set the scroll speed ( lower=faster)
int i;
int x;
int y;
char r_char;
char msg[] = " *** hello ***  "; //Change the text here.
//Columns
int clockPin1 = 2; //Arduino pin connected to Clock Pin 11 of 74HC595
int latchPin1 = 3; //Arduino pin connected to Latch Pin 12 of 74HC595
int dataPin1 = 4;  //Arduino pin connected to Data Pin 14 of 74HC595
//Rows
int clockPin2 = 5; //Arduino pin connected to Clock Pin 11 of 74HC595
int latchPin2 = 6; //Arduino pin connected to Latch Pin 12 of 74HC595
int dataPin2 = 7;  //Arduino pin connected to Data Pin 14 of 74HC595
//BITMAP
//Bits in this array represents one LED of the matrix
// 8 is # of rows, 6 is # of LED matrices
byte bitmap[8][7];
int numZones = sizeof(bitmap) / 8; // One Zone refers to one 8 x 8 Matrix ( Group of 8 columns)
int maxZoneIndex = numZones - 1;
int numCols = numZones * 8;
//Ticker Fonts
char alphabets[][8] = {
  //static unsigned char font5x7[][6] PROGMEM= {
  {0x00, 0x00, 0x00, 0x00, 0x00, 0x00}, // SPACE
  {0x0, 0x0, 0x0, 0xdf, 0xdf, 0xdf, 0x0, 0x0}, // !
  {0x00, 0x00, 0x07, 0x00, 0x07, 0x00}, // "
  {0x00, 0x14, 0x7F, 0x14, 0x7F, 0x14}, // #
  {0x00, 0x24, 0x2A, 0x7F, 0x2A, 0x12}, // $
  {0x00, 0x23, 0x13, 0x08, 0x64, 0x62}, // %
  {0x00, 0x36, 0x49, 0x55, 0x22, 0x50}, // &
  {0x00, 0x00, 0x05, 0x03, 0x00, 0x00}, // '
  {0x00, 0x00, 0x1C, 0x22, 0x41, 0x00}, // (
  {0x00, 0x00, 0x41, 0x22, 0x1C, 0x00}, // )
  //{0x00,0x14,0x08,0x3E,0x08,0x14}, // *
  {0x0, 0xc, 0x1e, 0x3e, 0x7c, 0x3e, 0x1e, 0xc}, //* CORAZON
  { 0x0, 0x18, 0x18, 0x7e, 0x7e, 0x18, 0x18, 0x0 }, // +
  { 0x0, 0x0, 0xb0, 0xb0, 0xf0, 0x70, 0x0, 0x0 }, // ,
  { 0x0, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x0 }, // -
  { 0x0, 0xe0, 0xe0, 0xe0, 0x0, 0x0, 0x0, 0x0 }, // .
  { 0x0, 0xc0, 0xe0, 0x70, 0x38, 0x1c, 0xe, 0x6 }, // /
  { 0x0, 0x7e, 0xff, 0xf3, 0xdb, 0xcf, 0xff, 0x7e }, // 0
  { 0x0, 0xc0, 0xc6, 0xff, 0xff, 0xff, 0xc0, 0xc0 }, // 1
  { 0x0, 0xc6, 0xe7, 0xe3, 0xf3, 0xff, 0xdf, 0xce }, // 2
  { 0x0, 0x62, 0xe3, 0xc3, 0xdb, 0xdb, 0xff, 0x6e }, // 3
  { 0x0, 0x30, 0x38, 0x3c, 0x36, 0xff, 0xff, 0x30 }, // 4
  { 0x0, 0x67, 0xcf, 0xdb, 0xdb, 0xdb, 0xfb, 0x73 }, // 5
  { 0x0, 0x7e, 0xff, 0xf3, 0xdb, 0xdb, 0xfb, 0x72 }, // 6
  { 0x0, 0xe3, 0xf3, 0x33, 0x1b, 0xb, 0xf, 0x7 }, // 7
  { 0x0, 0x76, 0xff, 0xdb, 0xdb, 0xdb, 0xff, 0x76 }, // 8
  { 0x0, 0x4e, 0xdf, 0xdb, 0xdb, 0xfb, 0xff, 0x7e }, // 9
  { 0x0, 0x0, 0x0, 0xee, 0xee, 0xee, 0x0, 0x0 }, // :
  { 0x0, 0x0, 0xb6, 0xb6, 0xf6, 0x76, 0x0, 0x0 }, // ;
  { 0x0, 0x0, 0x18, 0x3c, 0x66, 0xc3, 0x81, 0x0 }, // <
  { 0x0, 0x6c, 0x6c, 0x6c, 0x6c, 0x6c, 0x0, 0x0 }, // =
  { 0x0, 0x0, 0x81, 0xc3, 0x66, 0x3c, 0x18, 0x0 }, // >
  {0x0, 0x0, 0x6, 0x7, 0xd3, 0xdb, 0x1f, 0xe}, // ?
  { 0x0, 0x7e, 0xc3, 0xbd, 0xa5, 0xbd, 0xa3, 0x3e }, // @
  {0x0, 0xfe, 0xff, 0x1b, 0x1b, 0x1b, 0xff, 0xfe}, // A
  {0x0, 0xff, 0xff, 0xdb, 0xdb, 0xdb, 0xff, 0x7e}, // B
  {0x0, 0x7e, 0xff, 0xc3, 0xc3, 0xc3, 0xe7, 0x66}, // C
  {0x0, 0xff, 0xff, 0xc3, 0xc3, 0xc3, 0xff, 0x7e}, // D
  {0x0, 0xff, 0xff, 0xdb, 0xdb, 0xdb, 0xdb, 0xdb}, // E
  {0x0, 0xff, 0xff, 0x1b, 0x1b, 0x1b, 0x3, 0x3}, // F
  {0x0, 0x7e, 0xff, 0xc3, 0xdb, 0xdb, 0xfb, 0x72}, // G
  {0x0, 0xff, 0xff, 0x18, 0x18, 0x18, 0xff, 0xff}, // H
  {0x0, 0xc3, 0xc3, 0xff, 0xff, 0xff, 0xc3, 0xc3}, // I
  {0x0, 0x60, 0xe3, 0xc3, 0xff, 0x7f, 0x3, 0x3}, // J
  {0x0, 0xff, 0xff, 0x18, 0x3c, 0x66, 0xc3, 0x81}, // K
  {0x0, 0xff, 0xff, 0xc0, 0xc0, 0xc0, 0xc0, 0xc0}, // L
  {0x0, 0xff, 0xff, 0x6, 0xc, 0x6, 0xff, 0xff}, // M
  {0x0, 0xff, 0xff, 0xe, 0x1c, 0x70, 0xff, 0xff}, // N
  {0x0, 0x7e, 0xff, 0xc3, 0xc3, 0xc3, 0xff, 0x7e}, // O
  {0x0, 0xff, 0xff, 0x1b, 0x1b, 0x1b, 0x1f, 0xe}, // P
  {0x0, 0x7e, 0xff, 0xc3, 0xd3, 0xe3, 0x7f, 0xbe}, // Q
  {0x0, 0xff, 0xff, 0x3b, 0x7b, 0x5b, 0x9f, 0x8e}, // R
  {0x0, 0x4e, 0xdf, 0xdb, 0xdb, 0xdb, 0xfb, 0x72}, // S
  {0x0, 0x3, 0x3, 0xff, 0xff, 0xff, 0x3, 0x3}, // T
  {0x0, 0x7f, 0xff, 0xc0, 0xc0, 0xc0, 0xff, 0x7f}, // U
  {0x0, 0x3f, 0x7f, 0xe0, 0xc0, 0xe0, 0x7f, 0x3f}, // V
  {0x0, 0x7f, 0xff, 0xe0, 0x30, 0xe0, 0xff, 0x7f}, // W
  {0x00, 0xc3, 0xe7, 0x7c, 0x18, 0x3c, 0xe7, 0xc3}, // X
  {0x0, 0xf, 0x1f, 0xfc, 0xf8, 0xfc, 0x1f, 0xf}, // Y
  {0x0, 0xe3, 0xf3, 0xd3, 0xcb, 0xcf, 0xc7, 0x0}, // Z
  {0x00, 0x00, 0x7F, 0x41, 0x41, 0x00}, // [
  { 0x0, 0x6, 0xe, 0x1c, 0x38, 0x70, 0xe0, 0xc0 }, // backslash
  {0x00, 0x00, 0x41, 0x41, 0x7F, 0x00}, // ]
  {0x00, 0x04, 0x02, 0x01, 0x02, 0x04}, // ^
  {0x00, 0x40, 0x40, 0x40, 0x40, 0x40}, // _
  {0x00, 0x00, 0x01, 0x02, 0x04, 0x00}, // `
  { 0x0, 0x64, 0xf6, 0xd6, 0xd6, 0xde, 0xfc, 0x78 }, // a
  { 0x0, 0xff, 0xff, 0xd8, 0xd8, 0xd8, 0xf8, 0x70 }, // b
  { 0x0, 0x7c, 0xfe, 0xc6, 0xc6, 0xc6, 0xee, 0x6c }, // c
  { 0x0, 0x70, 0xf8, 0xd8, 0xd8, 0xd8, 0xff, 0xff }, // d
  { 0x0, 0x7c, 0xfe, 0xd6, 0xd6, 0xd6, 0xde, 0x4c }, // e
  { 0x0, 0xfe, 0xff, 0x1b, 0x1b, 0x3, 0x7, 0x6 }, // f
  //{ 0x0,0x6c,0xde,0x92,0x92,0xd2,0xfe,0x7c }, // g
  { 0x0, 0xcc, 0xde, 0x9a, 0xba, 0xfa, 0xde, 0xc }, // g
  { 0x0, 0xff, 0xff, 0x18, 0x18, 0x18, 0xf8, 0xf0 }, // h
  { 0x0, 0x0, 0xf6, 0xf6, 0xf6, 0x0, 0x0 }, // i
  { 0x0, 0x60, 0xe0, 0xc0, 0xc0, 0xcb, 0xfb, 0x78 }, // j
  { 0x0, 0xff, 0xff, 0x30, 0x30, 0xcc, 0xcc, 0x84 }, // k
  { 0x0, 0xc0, 0xc0, 0xc1, 0xff, 0xff, 0xc0, 0xc0 }, // l
  { 0x0, 0xfc, 0xfe, 0xe, 0x1c, 0xe, 0xfe, 0xfc }, // m
  { 0x0, 0xfe, 0xfe, 0xc, 0x6, 0x6, 0xfe, 0xfc }, // n
  { 0x0, 0x7c, 0xfe, 0xc6, 0xc6, 0xc6, 0xfe, 0x7c }, // o
  { 0x0, 0xfc, 0xfe, 0x36, 0x36, 0x36, 0x3e, 0x1c }, // p
  { 0x0, 0x1c, 0x3e, 0x36, 0x36, 0x36, 0xfe, 0xfe }, // q
  { 0x0, 0xfe, 0xfc, 0xe, 0x6, 0x6, 0xe, 0x1c }, // r
  { 0x0, 0x4c, 0xde, 0xd6, 0xd6, 0xd6, 0xf6, 0x74 }, // s
  { 0x0, 0x6, 0x7f, 0xff, 0xc6, 0xc0, 0xe0, 0x70 }, // t
  { 0x0, 0x7e, 0xfe, 0xc0, 0xc0, 0xc0, 0xfe, 0x7e }, // u
  { 0x0, 0x1e, 0x7e, 0xe0, 0xc0, 0xe0, 0x7e, 0x1e }, // v
  { 0x0, 0x7e, 0xfe, 0xe0, 0x70, 0xe0, 0xfe, 0x7e }, // w
  { 0x0, 0xc6, 0xee, 0x7c, 0x38, 0x7c, 0xee, 0xc6 }, // x
  { 0x0, 0x4e, 0xde, 0xd8, 0xd8, 0xd8, 0xfe, 0x7e }, // y
  { 0x0, 0xc6, 0xe6, 0xf6, 0xd6, 0xde, 0xce, 0xc6 }, // z
  {0x00, 0x00, 0x08, 0x36, 0x41, 0x00}, // {
OP’s Code (part 2)
void clearBitmap()
  //Clear bitmap
  for (int row = 0; row < 8; row++) {
    for (int zone = 0; zone <= maxZoneIndex; zone++) {
      bitmap[row][zone] = 0;
  pinMode(latchPin1, OUTPUT);
  pinMode(clockPin1, OUTPUT);
  pinMode(dataPin1, OUTPUT);
  pinMode(latchPin2, OUTPUT);
  pinMode(clockPin2, OUTPUT);
  pinMode(dataPin2, OUTPUT);
  clearBitmap();
//FUNCTIONS
// Displays bitmap array in the matrix
void RefreshDisplay()
    int rowbit = 1 << row;
    digitalWrite(latchPin2, LOW);//Hold latchPin LOW for transmitting data
    shiftOut(dataPin2, clockPin2, LSBFIRST, rowbit);   //Transmit data
    //Start sending column bytes
    digitalWrite(latchPin1, LOW);//Hold latchPin LOW for transmitting data
    //Shift out to each matrix
    for (int zone = maxZoneIndex; zone >= 0; zone--)
      shiftOut(dataPin1, clockPin1, MSBFIRST, bitmap[row][zone]);
    //flip both latches at once to eliminate flicker
    digitalWrite(latchPin1, HIGH);//Return the latch pin 1 high to signal chip
    digitalWrite(latchPin2, HIGH);//Return the latch pin 2 high to signal chip
    //Wait
    delayMicroseconds(300);
// Converts row and colum to bitmap bit and turn it off/on
void Plot(int col, int row, bool isOn)
  int zone = col / 8;
  int colBitIndex = x % 8;
  byte colBit = 1 << colBitIndex;
  if (isOn)
    bitmap[row][zone] =  bitmap[y][zone] | colBit;
    bitmap[row][zone] =  bitmap[y][zone] & (~colBit);
// Plot each character of the message one column at a time, updated the display, shift bitmap left.
void XProcess()
  for (charIndex = 0; charIndex < (sizeof(msg) - 1); charIndex++)
    int alphabetIndex = msg[charIndex] - ' ';                                      // I changed '@' to ' ' to display the different alphabets
    if (alphabetIndex < 0) alphabetIndex = 0;
    //Draw one character of the message
    // Each character is 5 columns wide, loop two more times to create 2 pixel space betwen characters
    for (int col = 0; col < 8; col++)
        // Set the pixel to what the alphabet say for columns 0 thru 4, but always leave columns 5 and 6 blank.
        bool isOn = 0;
        if (col < 8) isOn = bitRead( alphabets[alphabetIndex][col], 7 - row ) == 1;
        Plot( numCols - 1, row, isOn); //Draw on the rightmost column, the shift loop below will scroll it leftward.
      for (int refreshCount = 0; refreshCount < scrollspeed; refreshCount++)
        RefreshDisplay();
      //Shift the bitmap one column to left
        for (int zone = 0; zone < numZones; zone++)
          //This right shift would show as a left scroll on display because leftmost column is represented by least significant bit of the byte.
          bitmap[row][zone] = bitmap[row][zone] >> 1;
          // Shift over lowest bit from the next zone as highest bit of this zone.
          if (zone < maxZoneIndex) bitWrite(bitmap[row][zone], 7, bitRead(bitmap[row][zone + 1], 0));
void serialInput() {
  //check if serial is avaible an before reading a new message delete's the old message
  if (Serial.available()) {
    for (i = 0; i < 105; i++) {
      msg[i] = '\0';
    //resests the index
    charIndex = 0;
  //while is reading the message
  while (Serial.available()) {
    //the message can have up to 100 characters
    if (charIndex < (max_char - 1))
      r_char = Serial.read();      // Reads a character
      msg[charIndex] = r_char;     // Stores the character in message array
      charIndex++;                     // Increment position
      msg[charIndex] = '\0';       // Delete the last position
  XProcess();
  serialInput();
There are a couple of serious problems with the serialInput function. The first being that msg does not have 105 elements, so you will be writing past the end of the array. It is also highly unlikely that msg will contain more than one or two characters at any time because the serial input is so much slower that the arduino.
Thanks for replying
You can give the codes I will test
The photo I have attached is scrolling…
I don’t want to scroll
