7segment cap?
ok, i'm using a 4x4 keypad to control outputs on a 7 segment diode, but i can only make it show 1,2 and 3. if i try to push buttons above that, the 7seg goes crazy .
heres my code:
//http://www.arduino.cc/playground/Code/Keypad
#include <Keypad.h> // Download Keypad.zip
//define the cymbols on the buttons of the keypads
char hexaKeys[4][4] = {
 'A', 'B', 'C', 'D',
 'E', 'F', 'G', 'H',
 'I', 'J', 'K', 'L',
 'M', 'N', 'O', 'P'
byte rows = 4; //four rows
byte cols = 4; //four columns
byte rowPins[] = {2,3,4,5}; //connect to the row pinouts of the keypad
byte colPins[] = {6,7,8,9}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad(makeKeymap(hexaKeys), rowPins, colPins, rows, cols);
void setup(){
 pinMode(32, OUTPUT);
  pinMode(33, OUTPUT);
  pinMode(34, OUTPUT);
  pinMode(35, OUTPUT);
  pinMode(36, OUTPUT);
  pinMode(37, OUTPUT);
  pinMode(38, OUTPUT);
  pinMode(39, OUTPUT);
  digitalWrite(39, 1);
void loop(){
 char key = keypad.getKey();
 if (key != NO_KEY) {
   key -= 'A'-1;
   Serial.println(key,DEC);
   if (key == 1){ // 1
digitalWrite(32, 1);
 digitalWrite(33, 0);
 digitalWrite(34, 0);
 digitalWrite(35, 1);
 digitalWrite(36, 1);
 digitalWrite(37, 1);
 digitalWrite(38, 1);
 if (key == 2){ // 2
  digitalWrite(32, 0);
 digitalWrite(34, 1);
 digitalWrite(35, 0);
 digitalWrite(36, 0);
 digitalWrite(38, 0);
 if (key == 3) { // 3
 if (key == 5) { //4
    digitalWrite(2, 1);
 digitalWrite(3, 0);
 digitalWrite(4, 0);
 digitalWrite(5, 1);
 digitalWrite(6, 1);
 digitalWrite(7, 0);
 digitalWrite(8, 0);
 if (key == 6) { //5
   digitalWrite(2, 0);
 digitalWrite(3, 1);
 digitalWrite(4, 0);
 digitalWrite(5, 0);
 digitalWrite(6, 1);
 digitalWrite(7, 0);
 digitalWrite(8, 0);
 if (key == 7) { //6
   digitalWrite(2, 0);
 digitalWrite(3, 1);
 digitalWrite(4, 0);
 digitalWrite(5, 0);
 digitalWrite(6, 0);
 digitalWrite(7, 0);
 digitalWrite(8, 0);
 if (key == 9) { // 7
   digitalWrite(2, 0);
 digitalWrite(3, 0);
 digitalWrite(4, 0);
 digitalWrite(5, 1);
 digitalWrite(6, 1);
 digitalWrite(7, 1);
 digitalWrite(8, 1);
 if (key == 10) { // 8
   digitalWrite(2, 0);
 digitalWrite(3, 0);
 digitalWrite(4, 0);
 digitalWrite(5, 0);
 digitalWrite(6, 0);
 digitalWrite(7, 0);
 digitalWrite(8, 0);
 if (key == 11) { // 9
    digitalWrite(2, 0);
 digitalWrite(3, 0);
 digitalWrite(4, 0);
 digitalWrite(5, 1);
 digitalWrite(6, 1);
 digitalWrite(7, 0);
 digitalWrite(8, 0);
i'm not sure what i'm doing wrong because it compiles just fine. :confused:
Could it be that beyond 3, you appear to use a different set of pins?
The compiler has no way of knowing what you write is sensible or possible, just that it is syntactically correct.
I use all the same pins for all the numbers, just turn on and turn off commands. and i'm litteraly clueless how my 1, 2 and 3 works just fine and rest doesent :confused:
 if (key == 5) { //4
    digitalWrite(2, 1);
 digitalWrite(3, 0);
 digitalWrite(4, 0);
Right.
omg lol, i can't believe i made that fucking mistake AGAIN. thanks for pointing it out :slight_smile:
works like a charm :b
It could be considered overkill in such a short sketch, but any kind of human repetition (even if simply cut-and-paste) is prone to hard-to-spot bugs.
If you only ever reference the segment pins once, your code would be simpler to write and debug.
So, for instance, the digit patterns for a seven segment digit can be encoded in a single byte (with space left for a decimal point!), with one pit per segment.
A first stab at simplification could be like:
void displayDigit (byte pattern)
  for (int i = 0; i < 7;++i ) {
    digitalWrite (segmentPin [i], bitRead (pattern, i));
all you need to do is set up the array "segmentPin", and define your digit patterns in a separate "byte" array.
This approach also has the advantage that if you decide to swap common anode for common cathode displays, you need change only one line!
