8 bit RGB value to 16 bit Colour Value for Nextion Display
Hello,
I am working on a simple project which uses an ESP8266 to receive data from a web server from a colour picker. I have that working and all I need to do now is to send that value to a nextion display. However the nextion display only supports 16 bit colour values ranging from 0 to 65535 whilst the colour picker on my web server sends back a 24 bit RGB value ranging from 0 to 255 for each primary colour (eg, red = 255, green = 67, blue=100).
(Note: Each colour in the RGB value is 8 bits, since there are 3 the total amount is 24 bits)
Is there a way to convert the 24 bit RGB value to the 16bit colour value for the display?
Ryan
techinc1510:
Hello,
Ryan
looking at the RGB565 16 Bit Color Code
IMHO you could used the map function.
so doing something like this maybe....
uint16_t red_565 = map(red_value, 0, 255, 0, 31);
uint16_t green_565 = map(green_value, 0, 255, 0, 63);
uint16_t blue_565 = map(blue_value, 0, 255, 0, 31);
then combine them to get the 16 bit colour value like:
uint16_t rgb_565 = (red_565<<11)|(green_565<<5)|blue_565;
bear in mind that it is very likely that you will lose some colour tones.
hope that helps...
EDIT:
corrected
uint16_t green_565 = map(green_value, 0, 255, 0, 31); to uint16_t green_565 = map(green_value, 0, 255, 0, 63);
// rgb565     version 2
// Convert a hexadecimal rgb value into a rgb565 format.
// To be able to use HTML RGB color format in a Arduino sketch.
// When a text is needed, then the result can converted into
// a decimal number as text with a sprintf with %u, or with utoa().
// Great HTML color picker tool:
//   https://www.w3schools.com/colors/colors_picker.asp
uint16_t rgb565( const unsigned long rgb)
  uint16_t R = (rgb >> 16) & 0xFF;
  uint16_t G = (rgb >>  8) & 0xFF;
  uint16_t B = (rgb      ) & 0xFF;
  uint16_t ret  = (R & 0xF8) << 8;  // 5 bits
           ret |= (G & 0xFC) << 3;  // 6 bits
           ret |= (B & 0xF8) >> 3;  // 5 bits
  return( ret);
sherzaad:
hope that helps...
Can confirm this works, thanks for your help
Hope this helps someone else too!
Ryan
techinc1510:
Ryan
That’s good news! just one thing to point out…
uint16_t green_565 = map(green_value, 0, 255, 0, 31); should be
uint16_t green_565 = map(green_value, 0, 255, 0, 63); since 6 bits and not 5 is allocated for green
