8 blinking leds
i am trying to make program of 8 blinking using port manipulation technique. I have used port B pin (6-13). I am getting an error quoted " DDRB was not declared in this scope". I have attached the image. If any one can help me out with it, it would be great help :slight_smile:
DDRB = DDRB| B111111;
PORTB = B111111;// turn the LED on (HIGH is the voltage level)
  delay(1000); // wait for a second
PORTB = B000000;    // turn the LED off by making the voltage LOW
I see that you are compiling the code for a Due. Does it have the same ports as the 328 based boards ?
Yes, I have been using Due. And no, it has more number of ports than 328 based boards. Can you help me out with it??
The Due is a different processor (ARM-based) to the 328 boards (AVR) - you cannot simply use the same port manipulation registers.
Then what should be I doing if I don't want to increase my code lines and still control all the pins using less function?
If I were that desperate, I'd be picking apart "wiring_digital.c" and "wiring_digital.h" in "sam/cores/arduino"
I'm not that desperate.
shreerajshah95:
How important is it that the LEDs turn on and off at exactly the same time ?
It is very important for led's to blink at the exact time as expected. Is there any alternative for it in 'Arduino Due' other than the code i wrote??
UKHeliBob:
What is it that reacts to the blinking of the LEDs ?
Why not just use one output, digitalWrite() and 8 transistors to turn on the LEDs or output a byte with a value of 255 to a shift register and do it that way ?
